Go to Post The robot uprising has begun. - SpoonMechanic [more]
Unread 30-01-2002, 15:12
beakes beakes is offline
beakes is an unknown quantity at this point
Question Mounting Drill Motors Using Plastic Housing
A few have mentioned they have mounted the drill motors using the plastic housing. We are a second-year team and are considering this approach due to time constraints. Any suggestions on how get this assembly aligned with our drive shaft?
Unread 30-01-2002, 15:47
Unsung FIRST Hero
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Rookie Year: 1998
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
First of all, just place them in the drill motor housing. Then, cut off the handle of the drill motor and mount them so that they would be right side up for a drill. Then just secure them at the top and they should reasonably stay in place.
Matt
Unread 30-01-2002, 17:04
Question
The alignment I am having trouble with is between the transmission in the housing and the driveshaft of our drivetrain assembly. Any ideas on how to mount the housing to our drivetrain so that the shafts align? Anyone try using the flexible coupling?
Unread 31-01-2002, 00:05
CharlieWilken CharlieWilken is offline
#0634 (Robowolves)
CharlieWilken is an unknown quantity at this point
We just drill and tap a 3/8 24 hole in the end of a 1/2 in piece of cold rolled steel. Then put the other end of the shaft in a 1/2 inch bearing with bearing block.
plastic hubs and drill motors Will Camisa General Forum 4 01-03-2003 00:03
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
