Go to Post well yeah, but we can dream, can't we? - Nuttyman54 [more]
Unread 23-09-2003, 10:52
Dr.Bot
Posts: n/a
Controller Vintage.
Are the OIs and RCs made for 2003 different from 2000-2002?
Some teams at the Cal games had a bunch of trouble in competition (but not when running the machine alone). THese problems were fixed by switching out either the OI, the RC or both. The 'bad' unit then appeared to work fine when not hooked up through the arena controller.
Anyone have any insight on this? Maybe Tony from InnovationFIRST? One though is the OI might have a bad program.
Unread 23-09-2003, 11:09
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Not that I am Tony's spokesman or anything...
Yes, the controllers are different. Innovation First provides upgrades here.. A 2002 controller had to be upgraded in order to operate for the 2003 game.
We did this for our 2002 controller, but I don't know the specifics of what part of the program needed to be upgraded. I think that it was a combination of the autonomous mode addition in 2003 and how the field controllers interfaced with the robots during this time.
Anyway... yes... all of those 2002 controllers (robot and operator) needed to be updated if they were going to be used for the 2003 game.
Andy B.
Unread 23-09-2003, 16:23
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
I thnk the only difference in the robot controller is that it allowed you to display a user defined variable on the operator interface
and the pre 2003 ones wont do that
our robot controller was damaged during the practice matches at the canadian regional, and the guy from Innovation FIRST said we could use our spare (from last year)
it worked fine for us.
I dont know if the operator interface unit is different between '02 and '03
Unread 23-09-2003, 17:12
xplod1236's Avatar
xplod1236 xplod1236 is offline
None #0818 (Genesis '02)
xplod1236 will become famous soon enoughxplod1236 will become famous soon enough
Send a message via AIM to xplod1236
Yes, the OI for 2003 is different from the one for 2002. We went to Kettering this past weekend, and we couldn't find the OI from 2003, so we used an '02 one. We ran the robot before Kettering, and everything worked fine, including the atonymous mode. But when the OI was hooked up through the arena controller, the big blue/red light was blinking. The OI confirmed a valid Tx/Rx, but our atonymous mode did not work properly. The lights on the robot turned on, but the robot did not move. The rest of the match was normal. For the rest of the day, we borrowed an OI from another team (not sure which one), and it all worked fine. The OI from 2002 did communicate with the RC, but it did not work properly with the '03 arena controllers.
Unread 23-09-2003, 17:43
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
as i helped run the IRI scoring system and match system, i learned about the problems with the 2002 and prior controllers trying to work with the 2003 arena comp ports. the bot will work like normal under controller mode, where your drivers drive it, but before the match starts, through all of autonomous mode, the station (drivers booth) light will flash and auton mode wont work on your bot. It has to do with the controller software, and how the 2003 OI's are designed to work with auton, as the prior ones weren't made for that purpose.
~Mike
-Michael Dessingue
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
