Go to Post I hope Dave doesn't see these. He'll want you to put in a banana and use it for a game clue. - IndySam [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 31-01-2002, 13:00
junkyarddawg junkyarddawg is offline
junkyarddawg is an unknown quantity at this point
DC Motor current to an Analog Input
If this is already covered, my apologies. But, measuring magnetic field strength of DC current is the easiest method with the restraints put on the on the wiring by rule. This can be accomplished with an AMR or GMR or Hall Effect sensor, all available in the DigiKey Catalog. Look in the sensor section. If you then go to the web sites of the mfg., you'll find application notes to help you determine the exact distance from the center of the wire and angle to the wire to get the 0-125A range, 0-500A range etc.......
Chief Delphi Invitational 2003 - input Mike Martus General Forum 4 03-09-2003 13:23
Robot Controller Digital Input crazycliffy Electrical 11 16-02-2003 04:28
Programming port input? Rickertsen2 Rumor Mill 1 21-01-2003 17:26
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
Need some input --- Brandon Martus CD Forum Support 8 14-12-2002 15:55
