Go to Post Also, I did not know that Autodesk had changed our name from WildStang to "Digital Cheetanators"? - Raul [more]
Unread 30-09-2003, 22:27
wayne 05 wayne 05 is offline
wayne 05 is an unknown quantity at this point
switch speed control
How can i program a joystick trigger to scale down the speed of a motor
Unread 30-09-2003, 22:28
djcapelis's Avatar
djcapelis djcapelis is offline
Fried Manic Custard
None #0675 (Geeks with Power Tools)
djcapelis will become famous soon enoughdjcapelis will become famous soon enough
Send a message via ICQ to djcapelis Send a message via AIM to djcapelis Send a message via Yahoo to djcapelis
That would be difficult, it's either on or off... so you could turn the motor on or off...
unless you want to try funky pattern timing...
"I have more friends than enemies, I'm working to resolve the issue."
Unread 30-09-2003, 22:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
perhaps he meant scale the speed.
Ex: if you have a really fast robot, maybe you want to scale the speed down to 3/4 of full speed for more control. I think he is talking about using the trigger to do something like this. I know we did this for some odd reason at Cal Games, but I dont know jack about programming, so I cant help you.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 30-09-2003, 22:51
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
You could key off of the trigger to indicate the addition or subtraction of a fixed value (1,5,10) to a pwm output.
Initialize to a pwm output of neutral (127). Then, you'll need a direction bit (fwd/rev) so you know whether to add or subtract, and a trigger latch bit so you don't loop through the code a bunch of times, changing the pwm, before you let go of the trigger. You'll also want to min and max (1, 254) so you don't roll over.
Don't PANIC!
S. P. A. M.
Unread 30-09-2003, 23:37
djcapelis's Avatar
Fried Manic Custard
Or set a static entry if you just want to tone it down to 3/4 or total or whatnot... Then just hit trigger and get 3/4 speed ahead, interesting actually... hmmm.
Unread 01-10-2003, 00:53
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Yeah, you could have it that every x amount of loops it adds 5 to the PWM input. About 30-40 program loops is a second.
Just use PWM = PWM + 5 MAX 250 so you don't wrap around.
The other option is to have it turn on or off. This is more limited, but easier to deal with.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 01-10-2003, 09:35
Neal Turett Neal Turett is offline
Neal Turett is on a distinguished road
I'm interperting your request as if you have a joystick, and you want to be able to press a button on it to slow down the robot, in order to make it more controllable.
If this is what you're looking for insert this write after the code block where you tie the p1_y and p1_x (or whatever vars you use) to the pwms:
if (p1_top = 1) then
if pwm1 > 127 then pwm1 = (pwm1-127) / 2 + 127
if pwm1 < 127 then pwm1 = (127 - (127-pwm1) / 2)
endif
Do the same for pwm2. This will reduce the speed of the robot by a factor of 2 when p1_top is pressed.
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Prgm4 2 joystics control 1 speed cntrl??? punarhero Programming 7 21-02-2002 09:57
speed control punarhero Technical Discussion 11 24-01-2002 18:03
