Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 16-10-2003, 13:12
vladg12 vladg12 is offline
vladg12 is an unknown quantity at this point
Programming the PIC
Over the summer, I worked with a Cerebellum, a development board for the PIC16F877 developed at CMU, and it uses the same serial port for both programming and serial communications. You just leave the PIC in it's socket, and the board has I/O pins on it. I imagine a similar setup will be used by Innovation First (considering that having everyone removing the chip, programming it, and putting it back in will probably result in several snapped pins, if not chips, during the heat of the competition)
Unread 18-10-2003, 02:18
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
So I went and actually looked at the sheet for the 18F8520, and it has a bus available to address an acre or two of external memory (will the IFI RC ?), 32 k of internal program memory and 2 k of variable space in RAM and 1k in EEPROM. It has hardware serial communications options including a USART (rs232,488 &c), and IsquaredC, as well as all the stuff to read the PWM inputs.
The programming for all these goodies will probably be in the library supplied with C-BOT.
Unread 18-10-2003, 02:26
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
The default code for the EduRC was released yesterday (10-16-03). It's available here, under Documentation.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 19-10-2003, 19:36
Adam Collet Adam Collet is offline
#0159 (Alpine Robotics)
Adam Collet is an unknown quantity at this point
thanks
Thanks to all that answered my question of where to get good teaching aids (or however exactly I phrased it). A particular thanks to those who posted links to useful sites. Overall, a good thread, and helpful to me, so thank you on the whole.
Jesse - as for our team going CVS ... maybe, we shall see ... personally I am liking MPLAB a lot, which apparently doesn't support it, so ... we will talk
"Without the wind, the grass does not move. Without software, hardware is useless.''
Thus spake the Master Programmer
The Tao of Programming
Translated by: Geoffrey James
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
Robots and the Learning Channel.... archiver 2000 0 24-06-2002 00:16
