Go to Post Powerhouse teams aren't powerhouse because they build great robots, they are powerhouses because they build great teams. - couvillion [more]
Unread 31-01-2002, 22:30
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
Subtotaling in PBASIC?
This is a pretty obvious question:
Is it possible to subtotal in PBASIC? Like, every time a cycle completes, a variable, lets call it Counter, goes up one?
I know in C++ to do that it's simple, just one line of code:
Counter = Counter + 1;
or
Counter++;
If I can, how can I do that in PBASIC? My other programming sidekick thought it would just be:
Then, once a cycle, Counter would increase one integer, and eventually a "If Statement" would reset it to zero. I'm not sure if that syntax is right, and I figured might as well ask, and save some time and lots of possible fustration, as was caused with the switch operated PWMs, as some of you know . So, if I'm right, thanks, if I'm completely wrong, well, don't feel bad to be brutaly honest, even though that really isn't the spirit here, which is good.
Thanks,
Ian W.
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Need to learn PBASIC...Where Should I Go? IMDWalrus Programming 5 29-04-2003 16:43
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
RoboEmu v.1a (another PBASIC emulator) rbayer Programming 0 07-07-2002 00:45
