Go to Post MAVERICKS, do ride horses...all while building robots. They also build horses. - Corey Balint [more]
Unread 15-10-2003, 08:25
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
CIM Press Fit
Anyone out there have a good press fit bore dimension for the CIM motor to press into a gear cluster. (Not that we would be prototyping a gearbox or anything this is for something totally different......
We tried a few different ones last year and at one point if it is too tight the bearing in the endcap of the motor moves and the motor shaft gets sloppy
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 16-10-2003, 07:55
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Matt,
Raul (Team 111) posted that he used .001" press this past year on the CIM motors. I do not like to use a press fit because all my gears have had an outside diameter greater than the .75" boss diameter. Pressing on means disassembling the gearbox in order to change the motor.
Have you considered gluing the gears on? With a key and a light slip fit, a liitle bit of loctite would secure the gears and still allow disassembly.
Andy
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
CIM motors - where to buy spares? Andy Baker Motors 4 16-01-2003 21:09
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
12 balls fit in the goal??? archiver 2001 7 23-06-2002 22:23
