Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 01-02-2002, 16:21
KennethToronto's Avatar
KennethToronto KennethToronto is offline
#0820 (Delta Tech)
KennethToronto is an unknown quantity at this point
Send a message via ICQ to KennethToronto
Question about Plywood thickness
The additional parts rules state that we may either use 1/2" thick or 1/4" plywood for the robot.
Logically... I "could" glue together a piece of 1/2'' and 1/4'' to make a 3/4'' board.
This "glued" 3/4'' board would be the same as a purchased 3/4'' board wouldn't it? So working from that...is there anything stopping me from using a 3/4'' board?
North Toronto CI
Delta Tech Team 820 Robotics
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
simple engineering question Ben Mitchell Technical Discussion 2 07-11-2001 07:50
