Go to Post ASPCA would be happy to know you are petting your watchdog rather than kicking it. - Ether [more]
Unread 01-02-2002, 18:47
OddOne OddOne is offline
OddOne is an unknown quantity at this point
Send a message via AIM to OddOne
Question Relay Outputs
I am new at this PBASIC language (although very experienced in VB), and I have a question about the output command. In this line:
[font=courier new] Serout USERCPU, OUTBAUD, [255,255,PWM1,relayA,PWM2,relayB,p3_y,p4_y,p1_x,p2_ x,p3_x,p4_x,p1_wheel,p2_wheel,p3_wheel,p4_wheel,12 7,127,127,127]FONT]
as far as I can tell, I can only use Relay ports A and B. I need to use 4 of the ports, at least. Where do I put the specified outputs in the Serout command? Or does that happen anywhere else?
Thanks
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
Relay outputs on rc jdawson Electrical 4 26-01-2003 12:51
Wiring the relay for the pnumatics Placebo OCCRA 3 05-11-2002 23:04
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
