I was poking through the default code in an effort to determine if we could program the Master PIC as well as the User PIC, and I found this odd stuff thither.
Code:
void
_entry (void)
_asm goto _startup _endasm
#pragma code _startup_scn
void
_startup (void)
_asm
// Initialize the stack pointer
lfsr 1, _stack lfsr 2, _stack clrf TBLPTRU, 0 // 1st silicon doesn't do this o
n POR
bcf FPFLAGS,RND,0 // Initialize rounding flag for floating point libs
// initialize the flash memory access configuration. this is harmless
// for non-flash devices, so we do it on all parts.
bsf 0xa6, 7, 0
bcf 0xa6, 6, 0
_endasm
loop:
Clear_Memory();
_do_cinit ();
// Call the user's main routine
main ();
goto loop;
} /* end _startup() */
Mmkay, so I look at this and I'm really lost. First of all, what does the underscore at the start of all these functions signify? Second, isn't assembler in C done like a function call? Thirdly, is that entry function even necessary? And last, I thought C programs started with the main function, but this code calls it instead... @_@
