Go to Post At the competitions you can look like an idiot and nobody cares, that makes me happy... - Laura 1547 [more]
Unread 01-02-2002, 21:46
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
Calibrating Pressure Switches
I need help. As you all should be able to tell, we need help calibrating the pressure switches. We're currently trying out using one, that goes up to about 110 PSI, with a time delay to let the pressure build up a bit more. And yes, our robot probably needs to go on a slimfast/subway diet.
So, we're trying to use only one pressure switch, the 110 PSI one, but it seems to be set to 100 PSI which is too low. I've read that these can be calibrated, but I can't see anything to calibrate them with. Can someone please help me? An advance thank you to anyone who can help.
Nason pressure switches JP_1163 Pneumatics 11 03-03-2003 23:03
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
