Go to Post Truly good teasers should give people a good place to start guessing, while still leaving some mystery and uncertainty. - Travis Covington [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 02-11-2003, 19:53
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
EDUBot controller app
I posted an application in the Programming White Papers that allows you to control the 2004 EDUBot. You will need to load the .hex file included in the setup package on the RC. It has four joystick inputs, currently mapped to the PWM inputs. It sends 10 bytes and two ints back to the PC which are displayed in a GUI.
I included the "user_routines.c" source file, which you can use to change the mappings. There are two structs defined, should be fairly easy to understand.
UPDATED ON 11/3. I fixed the timing issues, so the version downloaded from this link is the current release. I apologize if anyone got it last night, I jumped the gun a little when I posted it.
http://www.chiefdelphi.com/forums/pa...le&paperid=232
Tether for new EduBot Controller gburlison Programming 9 18-12-2003 17:53
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
