Go to Post do i even have to say anything about hurricane jeanne after my comments about charley, frances and ivan? :mad: but if i could, i would run all of them over with my robot... - Arefin Bari [more]
Unread 15-11-2003, 21:26
Victim of Fate Victim of Fate is offline
Frequent Contributor
#0476 (Adidar)
Team Role: Student
Victim of Fate is an unknown quantity at this point
Send a message via Yahoo to Victim of Fate
Top Speed
I need to know the highest speed attained with a FIRST robot, perferably during competition or practice, not highest predictied speed, but highest speed perferably in meters per second...
this will really help me out in my transmission design, which, i will probably post later when my friend CADs it.
thx
Unread 15-11-2003, 21:41
xplod1236's Avatar
xplod1236 xplod1236 is offline
None #0818 (Genesis '02)
xplod1236 will become famous soon enoughxplod1236 will become famous soon enough
Send a message via AIM to xplod1236
The top speed of 818's robot was about 10 mph, which is about 4.5 m/s.
Unread 15-11-2003, 21:52
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
10-12 fps is pretty fast...
While it is definitely possible to make faster robots, I think that 10-12 feet per second is a pretty good top speed for a FIRST robot.
Remember that acceleration matters too when you are not in a 1/4 mile race but negotiating a field with other robots, balls, etc. around.
Also, being fast can be important, but if you are only fast, you are likely to have some trouble pushing, climbing ramps, etc.
Shifters can help with some of this but only to a point.
Good luck.
Joe J.
Unread 15-11-2003, 21:59
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
in 2002 Kingman's bot went around 18 fps, and I believe that the second robot the Cheesy Poofs made this year went around 20 fps. Keep in mind that at these speeds your robot is likely not going to have enough torque to overcome friction and turn, unless you drop the center wheels 1/4" or so. Unless you are a very good driver, its also going to be very hard to control.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 15-11-2003, 22:17
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
early on we created a 'speed trap' using the optical sensors and an oscilloscope (measured how long the bot frame interrupted the beam as it went past)
with the drill motors locked in the high speed position, our bot was going fast. I just checked my notebook and I cant find the exact speed, but Im sure it was over 20mph - maybe as high as 25mph
mind you, the load was so high the bot would not go from a standstill by its self. We had to give it a push to get it going.
This was really all an accident - it was the first time we had driven the bot, and just happened to have the drillmotors locked in high gear instead of low.
Obviously we didnt use it that way in competition - but to get back to your question
the only thing that would limit the top speed of the bot is wind resistance, friction on the wheels and drive train, and the fact that the field is only 60 feet long. If you have a multispeed transmission, and a long enough 'runway' - then you could get one of these things going pretty quick
just like a radio control car: :c)
now im not saying you could get a FIRST bot going fast enough to jump over your house - well, maybe you could. watch the linked video and you decide !
http://showcase.netins.net/web/isuguy/housejump.wmv
Unread 16-11-2003, 11:09
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
571's 2003 copetition bot had a top speed of about 12-13 ft/sec.
that would be a little over 5 meters/sec. Using 2 drills and 2 chips, we had adequate acceleration, but turning could get difficult when the battery got low.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 16-11-2003, 15:40
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
That was our first robot, from 2002. I don't know if it was quite that fast, cause we had major friction problems. If we had overcome those completely, it would've been much faster.
I do know that at NYC, I "grabbed" a goal. The bot was across the field, and I had to get back, about ten seconds left. I also happened to be lined up with a goal, for the other team, that was empty. So, I go into full reverse, and slam into the goal and drive the goal into the player station.
After that match, we're inspecting our robot. I made a huge dent in the extruded aluminum, like, completely bent it out of shape. Several other teams saw it, and rumor spread that we grabbed goals by deforming our robot. Can't say it happened again.
That was also the regional that we snapped a piece of lexan off our robot, again, hitting a goal. To all the teams that say lexan can't shatter/crack/break, believe me, it can (I remember Team 19 didn't believe us).
AIM --> Woloi
Email --> ian@woloschin.com
Unread 16-11-2003, 18:48
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Rookie Year: 1997
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
I can tell you that team 25's Evil Machine from this year hit 13.6 ft/sec. Only 102's (Gearhead's) machine was comparable at NJ.
Frankly, robots moving that fast are hard to handle (as many who have seen EM in action can attest). I have a puncture in my right leg just below my knee from Aignam's practice driving to prove it too!
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 16-11-2003, 20:07
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
25 was definately the fastest bot I saw this year
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
Unread 16-11-2003, 21:16
#0476 (Adidar)
Team Role: Student
thx all, I think I have enough data to design my drive train now, if you guys still want to post say, to brag or continue posting information then by all means go ahead
Unread 16-11-2003, 21:43
NIck - you need to fix your sig. Your historical facts are a little skewed.
I believe Galileo was not inprisoned, I think he was placed under house arrest (confinded to his home).
and Im pretty sure Copernicus wasnt executed - he was reluctant to publish his ideas - and they were not taken very seriously until after his death.
another scientist, Giordano Bruno, was burned at the stake, for asserting space was infinite, and that other suns and solar systems, and earth like planets existed.
See: http://www.blupete.com/Literature/Bi...Copernicus.htm
Unread 16-12-2003, 22:10
IrisLab's Avatar
IrisLab IrisLab is offline
Mentor
AKA: Dave Page
#1466 (Webb School)
IrisLab will become famous soon enough
Re: Top Speed
Some folks say that "space" is finite but unbounded (like the surface of a sphere is finite yet unbounded as a 2D analog). I was just thinking that poor Bruno may have toasted for nothing.
Probably off topice but that hit me as funny.
Unread 16-11-2003, 22:15
#0476 (Adidar)
Team Role: Student
Exclamation
gee thx, I was pretty sure that Nicholas got put to death, but I dont want to start an argument about it, it was late at night when I made that one so please forgive any "historical errors" Thank god somebody found and corrected me before this little skew got out of hand.
That was all sarcasm, not my best, but it will have to do.
Next time, if you see a mistake as inconsequencial as that, just PM me so you dont get off topic in the forums, and besides, it makes me look bad to be the subject of public humiliation.
alright? Please show a little more tact when you "correct" someone offtopic.
thx.
PS. I still think he was executed
Unread 16-11-2003, 22:27
It wasnt inconsequencial to Copernicus :^)
didnt mean to put you on the spot publically - the internet is a vast storehouse of misinformation
now if someone read in your sig that Nicky got executed, and put it in a term paper or something, THAT would be humilating.
I make mistakes from time to time. I think Im up to 5 now :c)
BTW - one of the great things about forums like this is the stuff you learn and pickup - mostly OT stuff - kinda like a conversation where one topic or idea leads to another.
If we get 20 people off searching the web now to see what happened to those people, thats pretty cool.
PS: sorry for making you upset - wasnt intentional
  #15   Spotlight this post!
Unread 17-11-2003, 23:25
#0476 (Adidar)
Team Role: Student
yea, I have to apologize on that last post as well, it was also late at night after a cruddy weekend when I did that one
(hmm... Im begining to see a trend)
so dont sweat it.
Now Ive got to find something interesting for a new sig...
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
