Go to Post I would much rather educate the audience than dumb-down the game. - dlavery [more]
Unread 18-11-2003, 15:42
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
Gearbox/ Dual Motor Setup
Hello all,
I am a member on team 1024, The Kil-a-Bytes.
We are looking for any plans or blueprint of a gearbox or a dual motor setup. This off-season we are trying to build a faster drive train. If you have any thing you think could be of assistance, please share it with us. Thanks in advance.
Matt
Lead CAD
Unread 18-11-2003, 15:57
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Look in the White Papers section. There are several designs already posted. Take your choice.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 18-11-2003, 20:53
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
Our team has never mastered the art of gear boxes, but you can really do some great things with a few chains and sprockets. We are using this as a possible basis for the new robot. Looks like it should run very fast.
Unread 18-11-2003, 21:18
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Rookie Year: 2000
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
gotta love a ballsy battlebot chassis awesome! using those motors, it will be sooo robust!!
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 18-11-2003, 22:07
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
If you look closely at the above picture, you'll notice the chains being used to reduce the output from the motor are connected to a small sprocket on the shaft of the motor itself. There are three possible problems that might crop up with this arrangement.
Having such a small sprocket on that chain limits the maximum power it can reliably transfer. This was part of the reason that Blizzard 4 suffered several chain failures during the season. (Our drive sprocket was too small--25-pitch, 20-tooth.) Linked here is a (13 MB) reference that contains charts of maximum power for various sizes of chain (in terms of rotational speed and size of sprocket). These start on page A-6 (or 17 in Acrobat).
Related to Blizzard 4's chain troubles, there doesn't seem to be any idler system on that chain. While this can work (and has worked on many robots), the lack of an idler can put you at greater risk of chain slippage. If the chain isn't exactly the right size, you might find yourself missing a chain at an inopportune moment (and with chain, "exactly" isn't always a plus/minus one link situation).
Lastly, watch for the possibility of side loads on that motor. Some motors are more tolerant of this than others, depending on the way that their shafts are mounted in their bodies, and whether or not they incorporate internal gearheads. In general, a load (such as that introduced by an over-tightened chain) will tend to wear the motor at a significantly increased rate. (You might remember the warnings to never subject the Globe motors to a large side load, for this reason.)
Unread 18-11-2003, 22:13
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
That is why they make half links
Unread 18-11-2003, 22:22
Rookie Year: 1999
Which are half as strong ...
(Well, not quite half, but they are generally weaker than the regular links. And you know what they say about the weakest link...)
Unread 18-11-2003, 22:38
Team Role: Teacher
We never had a problem with them and we used drills and chias linked together for a total of a four motor drive. 1 drill + 1 chia per side. You can make out a half link in this pic
EDIT: This is also a pic of one way to do a dual motor drivetrain. You'll find a couple more pics here As a note, do not use nylon spacers under the pilllow blocks like we did. Make your own pillow blocks the correct height or use aluminum or steel spacers. While structurally safe, the nylon compressed when the mounting bolts were tightened making for horrible alignment at times.
Unread 02-12-2003, 09:43
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: Gearbox/ Dual Motor Setup
If your looking for a very simple 4 motor drive, probably one of the most simple I've seen that don't use gears would be from my high school teams (263) 2001 robot. Simply just the fp/bosch. (2001 was before the Atwood was added to the kit for anyone newer) fp(with its gearbox) geared up 1:3 to mate with the bosch(and its gearbox in low) and then geared 1:3 back down to a 12 inch wheel and ran about 5.5ft/s. Simple and elegant, 2001 LI regional winner and 2001 LI Delphi Driving Tomorrow's Technology winner. you could take that from the bosch and gear 1:1 to an 8 inch wheel and go approx 10ft/s if you are looking for a faster drive. A good approx of the robot speed can be done by taking
(wheel rpm X wheel diameter X pi) / 12 / 60
There are many old threads on this if you just look for them.
Another 4 motor drive example without gears is a timing belt combiner. (263 2002) The Atwood added in 2002 had a cluster gear given with it that mated with its output shaft. Then we attached a small 5:1 timing belt reduction onto that and it mated well with the bosch (and its gearbox in low). Then we did a sprocket reduction to the wheel. However both these designs required us to take appart the bosch gearbox and modify the output shaft to a standard 3/8 axel. Not a hard modification to do on your own.
Name:	croped 4 motor bosch fp copy2.jpg
ID:	1602  Click image for larger version
Follow me on twitter @roboticsrob and my FTC team @griffins10092
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
