sensors
will infared sensors work through glass? and can they be programmed to perform a function only after activated for a certain time, say 3 seconds?
What kind of infrared sensors are you using? The sensors don't do anything on their own, they just measure a value and let you know what it is. Its up to you to take that information and do something useful with it.
Infrared through glass
Not sure - [I know that UV doesn't go through glass]
But here's a way to check: Try it (under power) through the glass you plan to use, and if the light comes on, then you know it can .......if it doesn't, why not just drill a hole through the glass where you place the sensor. (Info came from Bob Koehl, engineer on Team Ford FIRST) |
IR LED's can be seen on a CamCorder
If you are trying to debug IR stuff, there is nothing so useful as a camcorder.
The CCD sensors are sensitive to infrared frequencies. Try it. It works. Joe J. |
IR will go through glass
it will also go through black electrical tape (its transparent to IR) |
sensor Last edited by Adam Y. : 19-11-2003 at 16:50. |
| Robotics Tournament at Sensors Expo & Conference | Kyle Fenton | Off-Season Events | 4 | 04-05-2003 12:15 |
| Q&A Discuss: Optical sensors with EduBot | CD47-Bot | Extra Discussion | 2 | 01-03-2003 18:37 |
| Q&A Discuss: optical sensors | CD47-Bot | Extra Discussion | 0 | 15-02-2003 22:58 |
| Robogui ! sensors don't work | Fares | Programming | 2 | 07-01-2003 16:31 |
| pre-built autonomous sensors? | BandChick | Technical Discussion | 4 | 05-01-2003 22:06 |
