Go to Post For example an iron block is very simple and very robust. Strap a control system on it and it will meet the requirements of being a FIRST robot. However, it sure doesn't do very much, nor is it innovative. - sanddrag [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 01-12-2003, 21:14
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Rookie Year: 2000
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
2D/3D Gear Design
I'm looking for a freebie gear maker, most likely in a macro form. I found this but it's only a 15 day trial then you have to pay. [Yes, the server is currently down, I know.]
Anywho, I've searched far and wide for another similar program but have come up with nothing. I understand how to make a standard spur type gear, but there are some that I can't grasp. I'm looking at miter and bevel gears out of the Small Parts Inc catalog and pulling other bits of information out of my Machinery's Handbook to try and make the gears on AutoCAD but it is a real pain.
Anyone know of an easier way to make gears?
Unread 01-12-2003, 21:36
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: 2D/3D Gear Design
I talked with some people about this question and what we decided is this:
Take the pitch diameter, and create a model of the gear (hub, bore, whatnot) but instead of teeth just make a cylinder with a diameter equal to the pitch diameter.
Inventor doesn't care about the difference. It is surely loads easier on your system (especially when you are placing/moving them . . . this can take some time on a middling machine).
So my advice is to just model the gears minus the teeth (using, again, the pitch diameter).
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 02-12-2003, 14:54
Gadget470's Avatar
A Fire Outside
Rookie Year: 2000
The point is that I want the teeth to be shown.
Unread 02-12-2003, 17:45
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Perhaps putting a bitmap on the cylinder would suffice?
Perhaps you could find what you are looking for at www.cadregister.com
Unread 02-12-2003, 18:38
#1067 (SLUH)
Ok, this is possible.
First, you need to find dimensions for each individual tooth (i.e. how far below the pitch diameter is the trough, how far above is the peak, what shape is it, etc.) and draw one tooth, then use circular pattern to draw all the teeth (after you extrude the first makes it easier) and viola.
But, you were asking about angle gears, weren't you.
In the FIRST CAD library thread there is a link to another collection of inventor files, and they have some angle gears there. Check them out.
Unread 02-12-2003, 23:31
Gadget470's Avatar
A Fire Outside
Rookie Year: 2000
As I said, I'm using AutoCAD not Inventor. I want to know how to create the gear, of any size from the info given. there are no iParts for AutoCAD that I know of.
I have the following information for each gear:
Diametrical Pitch
Number of Teeth
Pitch Diameter
Face
Bore
Mounting Distances
"D" (Base of Hub to Plane)
Hub Diameter
Hub Projection
Unread 03-12-2003, 14:20
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
is this what you are looking for?
http://www.cbliss.com/inventor/Parts/PowerTransmission/
most of these can be changed to any size gear by just changing a few numbers.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 03-12-2003, 14:28
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
I, too, have been unsuccessful in finding a macro or free plug-in to create any gear you need.
What I've found to work best barring that is to search SDP-SI (www.sdp-si.com) for the gear I need (if it's standard) and use their models. The models they have available for download often include one or two modeled teeth which you can then revolve around the gear and make a complete model.
Also, remember that unless you're doing this for rendering purposes, it's a lot less taxing on your hardware to model gears without teeth and makes mating them much easier.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 03-12-2003, 14:32
Let's have fun!
#1022 (ArcherGEeks)
Something else you can do is with a little know how, find a drawing like what is mentioned above and then tweak it with Inventor. You can create a spread sheet that you can link with your drawing. Then all you have to do to change the size of the gear would be to change a few numbers in the spread sheet and hit update and you will have unlimited number of gears for that design.
James Grim
www.youthbotin.org
Unread 03-12-2003, 14:42
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Ed Sparks' FIRST CAD Library site (www.firstcadlibrary.com) featured/s iParts for Inventor. The sprocket and gear never worked well for me, though. The geometry of gears is a little messy at times.
--Madison--
Unread 03-12-2003, 15:18
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
The best free program I've seen is called "geargen" it's some free dos type program that let's you create gears based on a few different options, then it plots them and you can export them as a few different file types including a .dxf which will open in AutoCAD (I think).
ftp://ftp.bu.edu/pub/mirrors/simteln...d/geargn11.zip
EDIT: Just extract it to a folder and run "GG110.EXE" Other than that you might want to read the readme file to see what to do.
Purdue Alumni
Cummins, Inc.
Unread 03-12-2003, 15:25
CURTIS's Avatar
CURTIS CURTIS is offline
CURTIS is an unknown quantity at this point
I suggest CAD Register.com (Thomas Register)
Unread 04-12-2003, 07:41
Gadget470's Avatar
A Fire Outside
Rookie Year: 2000
People please.. read the original post and replys by the original poster.
I Do Not Have Inventor.
I am looking for information on bevel gears.
I almost struck gold with what M said, but the drawings for bevel gears didn't include teeth on SPD-SI. However, those may be able to work for 2D Drawings. Clark, I have GearGen, but that works for Spur gears, which doesn't reeeeaaaaaly help me because while a bevel gear begins as a flared spur of sorts, i don't know the point where the tooth stops and begins because I'm only being given the Pitch circle.
Unread 11-12-2003, 13:26
indieFan indieFan is offline
RoboDox and LVHS - Missing you!
FRC #5941
indieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond reputeindieFan has a reputation beyond repute
Would it be possible to take all of the information that you have, create a spur gear like 2D drawing, and extrude it using an appropriate taper angle?
indieFan
  #15   Spotlight this post!
Unread 17-12-2003, 13:20
Gadget470's Avatar
A Fire Outside
Rookie Year: 2000
Possibly, but I honestly don't know, see the gears have an odd shape, they are not actually conical from top to bottom. More like:
Code:
  /'__________'\
 ¹---..    ..---¹   (Cut-away profile)
      |____|
  /'__________'\
 /____      ____\  (would work w/ Taper Angle)
      |____|
Edit:
Better yet:
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
