Go to Post What good will it do to have 10,000 teams who barely have a clue and are just scraping by versus 2,000 teams that are actually sustainable? - Cory [more]
Unread 02-12-2003, 02:01
JimWright949's Avatar
JimWright949 JimWright949 is offline
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
Hints for the Edu Interrupts
Hello all,
Since I'm a mentor I will not give you the answer as to how to get your interrupts running. However here is some usefull information:
1) In the Microchip library there is a function called OpenPORTB, find out what is does and put it in your initialization code.
2) When you are calling interrupts you need to "save the context", there is a note about this in the PIC18F8520 datasheet on the Microchip site. However this is for people writing assembler, and the C code will not need this.
3) You may not want to code a printf line into an interrupt. It is generally a bad idea in the embedded programming world. To test if the interrupt is working have it add 1 to a global variable. Put this line in your main.c outside the main function (line 23):
int global_counter;
Put the printf in the main:
printf("Counter=%d\n",global_counter);
Put this line in your user_routines_fast.c outside any functions (line 60):
extern int global_counter;
Put this code in the InterruptHandlerLow () function:
global_counter++;
When you run your program and close and open the Interrupts the count will increase.
-Jim Wright
My hints and guess on the Game in 2004! Elgin Clock Rumor Mill 116 09-01-2004 13:30
Problem with interrupts on the PIC Mike Betts Programming 7 16-12-2003 21:26
Interrupts on the EDU-RC? Andrew Programming 3 13-11-2003 23:16
Hints For Rookie Programmers Noah Programming 30 20-02-2003 20:07
Hints @ Kickoff Broadcast Nate Smith General Forum 13 05-01-2002 10:14
