Go to Post I WANT MY POOF BALLS! - Cyber Punk 234 [more]
Unread 02-12-2003, 10:17
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
"Cheap" Robot parts
not so cheap, But inexpensive .this year were being very frugile in our operation and ive been desinging with thaT in mind. and a part that costs $150 and you need... say 4 of them .Could run your money out quick
so, i guess im asking what parts, or manufactoring methods do others use to cut costs:?:
heres my Saviour...
theyre 4"x4"x5/16", hold 300 Pounds, and cost .84 cents each
(speelcheck isint up yet. Save me Brandon)
Unread 02-12-2003, 10:37
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Re: "Cheap" Robot parts
heres my Saviour...
Tytus has a great point. A good designer can make complex mechanisms which require many expensive parts, but a better designer can make the same mechanism with easy-to-get or cheap parts.
For instance, we made this "ball drive" last year. We wondered how to fabricate the core for the balls. The outside needed to be relatively hard, but tacky. We decided that urethane would work well for the outside, so we just needed to make a lightweight, hard ball. We looked to buy some, but had no luck. We were actually looking at having a guy CNC lathe some PVC plastic down to 2 hemispheres, but we found an answer: steel gazing globes. We could buy hollow steel balls from a landscaping company. These balls are called "gazing globes" and usually are glass. Some are steel. They were $6 per ball. We were glad to find a cheap, workable solution.
btw, Tytus... you can copy and paste your post in Word to perform a spell check.
Andy B.
Unread 02-12-2003, 12:25
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Yep. I totally Agree. In fact we used those bearings back in '02 to pivot our wheels. We eventually took them off (not because they didn't work) but they helped alot.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 02-12-2003, 12:28
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Gotta caution you though - I tried to use the part you have pictured in zone zeal as the pivot for our 2 arms (you'll see them in early pictures of Fluffy but not in the version that made it to nationals). We had flat run out of manufacturing resources and time to make the original bearing and support, so I did a quick redesign to use these off the shelf parts from McMaster Carr. They may take 300 pounds of load, but they have no stiffness or strength in off-axis torque. They actually performed better than I expected - the formed sheet metal managed to stay just close enough to keep the ball bearings from departing - but the lack of stiffness caused problems in the drive system (couldn't keep tension).
My favorite activity during week 1 is to go to home depot and stare at stuff for ideas, and to see what I could cluge together for a mechanism. Parts that already have integral hinges or bearings can save you a bunch of time and money. At worst you get a quick prototype; at best you get a functioning component.
Close enough to taste it, too far to reach it
Unread 02-12-2003, 21:35
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
An alternative to ball bearings: Just use bronze bushing.
Before assembly, be careful to make sure the mating interface to the bushing is very clean to avoid friction. And of course add some oil.
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 03-12-2003, 14:29
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
The best way to keep things cheap is to keep them simple. Don't let your design get out of hand. If you catch yourself adding parts here and there just to try and make a design work then maybe it's not a good design. I guess what I'm saying is don't try and design a hand when a claw will work.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 03-12-2003, 15:11
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Actually bronze bushings should be all ready lubricatd. They cotain little pores of oil that come out when the shaft moves fast enough.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 05-12-2003, 16:02
AKA: Ty
Raul
if you have a shaft runing fast enough the juberactioj is gonna disapper prety fast with that little setup
but i guess its good for slower-moving parts
Unread 05-12-2003, 17:24
Adam Y.'s Avatar
Adam Y.
no team (?????)
Errr I hope you mean lubercation. Anyway oil impregnated bushings do not have that problem since the oil is all ready in the bushing. (Note: I do not know if impregnated is the right word)
Unread 05-12-2003, 17:34
AKA: Ty
OMG! wheens spell check coming back and the orange?
Please everyone out there Dont give me anymore negative rep points for my spelling, i know im working on it
Unread 05-12-2003, 21:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Are either of you sure what you mean? (i.e. lubrication )
And yes, impregnated is the right word.
Unread 06-12-2003, 09:18
Rookie Year: 1998
Guys...
When an oil impregnated bearing (otherwise known as a bronze bushing) gets hot, then the oil starts to exit from the bearing. This hottness could be caused from an overloaded bearing (very high rpm and load) or something next to it getting very hot.
Andy B.
Unread 06-12-2003, 10:48
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
My advice on cheap parts is to remember that you don't have to order from MSC McMaster and 80/20. We were stuck in that track last year, wondering how we could lost weight and cost. For those 5 ft long wings you might have noticed we used some cheap conduit (sp? sorry, I don't have time to run Word). My advice is to take a trip to Lowes or something like that when you need ideas for parts. You can use so many different materials that they have there and they tend to be cheaper than ordering from these other companies.
P.S. If you get your stuff locally that also means that you can run out and get an extra one when you need it the day before shipping!
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 06-12-2003, 20:55
Adam Y.'s Avatar
Adam Y.
no team (?????)
Originally Posted by Andy Baker
Guys...
Andy B.
Is that good or bad? Should the lubrication stay inside it or outside it?
  #15   Spotlight this post!
Unread 07-12-2003, 09:46
Rookie Year: 1998
Once an oil impregnated bearing gets too hot, the oil sorta "boils out" of the bearing, then the bearing dries up and it does not work as well. The hole gets a bit bigger and the bearing is shot. It is definitely not a good thing... you want the oil to stay inside the bearing material.
Andy B.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
