Go to Post When all you're holding is a hammer, every problem looks like a nail. - artdutra04 [more]
Unread 07-12-2003, 19:08
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Wiring a dancing hamster to the RC
So, I found a dancing hamster named HAL that sings Mr. Roboto and looks like Robbie from Lost In Space. I think he's cute and I'd like to wire and bolt him to next year's robot and connect him to a giant "PANIC" button on the OI, just for fun.
My question is, how could I use the relay controls to control the hamster? He only has a little pushbutton switch in his foot. I think it'd be kind of bad for the batteries (3 AA, 4.5v) to simply connect the relay power to the hamster switch ground and the hamster power to the relay switch ground.
I thought about using an optoisolator (IR led + IR detector in a small black box, to keep two circuits apart from each other yet allow for signals to pass), but I've never used one before and don't want to build one from scratch. I know Victors have one in them to separate the regulated RC voltage from the battery voltage.
My last option that I've thought of is to use a servo to simply mash the hamster's foot to the top of the robot.
What do you guys think?
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 07-12-2003, 19:43
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: Wiring a dancing hamster to the RC
First of all LMAO @ this one. You have 2 really simple options:
1.) You can use an optoisolator. Be sure to bias it correctly
2.) You can use an spst relay. (probably the better option bc its more easily attainable)
Both are just as aesy and will work equally well.
1139 Alumni
Unread 07-12-2003, 20:12
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Well, if the thing runs on 3 AA's, I'd say just make a voltage divider for 4.5 volts and solder the leads to where the battery's make contact with the hamster. Then Bammo! Just flick the switch on the OI to activate the relay, and dance-ahoy!
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 13-12-2003, 10:51
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
ahahahahahahahahahahhhhhh...
I like the relay idea. Just snip the switch in the foot out of the circuit and put the relay in its place. Send video!
~~Aaron
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Unread 13-12-2003, 19:13
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Rookie Year: 1998
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Well if you are going to do this to the robot for next season, you woudn't necessarily need to use a spike. You could use the SPST reley linked by Mercutio, and hook it to a digital IO pin on the controller, like so:
Code:
+5V-----|    |------    Hampster
IO pin--|    \--------   Hampster battery
Excuse the ASCII art, I'm too lazy to draw it up properly...
Telephone wiring Lisa Rodriguez Chit-Chat 4 18-06-2003 00:22
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
The Plight of a Hamster in Flight archiver 2001 3 24-06-2002 03:14
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Diagrams for wiring of 15 and 25 pin connectors archiver 2000 2 23-06-2002 23:03
