Go to Post The championship event is a meta-game of inches. People will complain about unbalanced/unequal divisions, whether you think it's silly or not. - PayneTrain [more]
Unread 04-02-2002, 15:12
DakotaFox DakotaFox is offline
DakotaFox is an unknown quantity at this point
Question Wiring Compressor
We are trying to get the compressor running and controlled by the pressure switche.
There are no Programming Guru's here so we are very leery of trying to program the controller.
Does anybody know if it is acceptable (read legal) to do the following?
1) Wire a jumper to a 15 pin connector, attach it to the #3 joystick input so it drives the white wire of relay 5 output high.
2) Attach the other end of the 3 wire relay control wire to a Blue SPIKE Relay.
3) Cut the white wire, run it to the pressure switch and use the opening and closing of the pressure switch to make or brake the circuit to the Blue SPIKE Relay.
4) Connect the Blue SPIKE M+ to the red compressor wire and the black compressor wire to the relay block ground.
Page 11 , the sentence under table 2.1 seeps to imply that cable modification is OK.
Thanks
Problem with compressor Nick R. Pneumatics 3 21-02-2003 10:51
Air compressor never shuts off Carl Owenby Pneumatics 4 08-02-2003 23:34
compressor questions Greg Needel Pneumatics 2 29-01-2003 16:58
compressor? BBFIRSTCHICK Pneumatics 11 22-01-2003 07:12
programming the compressor archiver 2001 4 23-06-2002 23:19
