EDU robot programming
How would I go about changing the default program from single joy stick control to two joy stick control?
Re: EDU robot programming
Change the following lines in user_routines.c at the top of Default_Routine to get rid of the mixed result and just use the PWM inputs directly. Original code (get rid of the mixing): pwm01 = pwm03 = Limit_Mix(2000 + PWM_in1 + PWM_in2 - 127); /* LEFT WHEELS */ pwm02 = pwm04 = Limit_Mix(2000 + PWM_in2 - PWM_in1 + 127); /* RIGHT WHEELS */ pwm01 = pwm03 = 255 - pwm01; /* reverse direction of left side */ New code (just : pwm01 = pwm03 = 255 - PWM_in2; /* LEFT WHEELS - reverse direction of left side */ pwm02 = pwm04 = PWM_in4; /* RIGHT WHEELS */ |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| WASH Palm scouting at the Championship | Mike Soukup | Scouting | 2 | 19-04-2002 15:14 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
| Robot Programming Game | Brandon Martus | Chit-Chat | 3 | 10-09-2001 23:37 |
