Go to Post Scrap it and use the cheesey poof's design - vladtheimpaled [more]
Unread 11-12-2003, 02:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Making a forward only speed control reverse
Hey all you bright CDers.
I've got a challenge for you (actually it's more of a problem for myself). I need your help. I need to find out if there is any possible way to make a forward only speed control (where the power positive goes straight to the motor positive and the ground is what is being switched) into a forward and reverse speed control. I thought of putting a relay after it (before the motor) and using some fancy code. Would this work? Any other ideas?
Thanks
switch speed control wayne 05 Programming 6 01-10-2003 09:35
forward reverse on drill motor PDonovan Motors 2 03-02-2003 11:11
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
Speed of Atwood motors in forward and reverse... Dan 550 Motors 14 04-02-2002 19:55
speed control punarhero Technical Discussion 11 24-01-2002 18:03
