Need Help
HI
how are u i got a problem when i build a system I'm using delphi 7. I need source code for:- link to a page when user click a treeview nodes. +++++++++++++++++++++++++++ +++++++++++++++form+++++++++ +++++++++++++++++++++++++++ ++treeview ++++++++++++++++++ +++nodes++++++++++++++++++++ +++++++++++++++++++++++++++ +++++++++++++++++++++++++++ +++++++++++++++++++++++++++ +++++++++++++++++++++++++++ +++++++++++++++++++++++++++ +++++++++++++++++++++++++++ its most like option menu. ok thank you. can i anyone can help me pls ok bye Last edited by KLBADBOY : 11-12-2003 at 04:20. |
Re: Need Help
FIRST of all...this is not a forum dedicated to the Delphi programming language--it is instead concerned with the FIRST robotics competition, of which ChiefDelphi is a participating team. (So posting Delphi programming questions here is generally a bad idea.) That much said, I do know something about Delphi, so you may find this useful, just this once. (There are a number of good Delphi references on the internet--search for them. Try delphibasics.co.uk, and delphi.about.com, for example.)
Now, for the programming: Is there any reason why you can't use the OnClick event to call ShellExecute with the appropriate webpage as a parameter? (You may need to include the ShellAPI unit in the uses statement.) Maybe something like this: Code:
ShellExecute(Handle, 'open', 'http://www.chiefdelphi.com', Nil, Nil, SW_SHOWNORMAL); Note that this will spawn a new default browser window. If you want to have the links open inside of your program, you'll probably have to use an ActiveX browser control (that's too hard to explain here, if you're not familiar with it), and instruct the browser control to open the page, instead of using ShellExecute. Also note that using a TTreeView to display links to webpages is a very non-standard style, so be careful not to violate the user interface guidelines for Windows programs. Usually, a hyperlink would be blue, underlined, and obvious, instead of disguised in a TTreeView. To reiterate--don't post Delphi programming questions here any more, it's usually not worth it! ![]() |
