Go to Post You're here for them, not for you. - Chris is me [more]
Unread 14-12-2003, 16:55
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
EDU Demo Code: Real-Time Clock Using a Timer
Using the template code I wrote earlier, I've written a demo application that displays the elapsed time to the console window. From the description in the code:
This demonstrates the use of a timer and associated interrupt. In this example we'll setup a timer to generate an interrupt every millisecond (= 1000Hz rate). In response to this interrupt, the microcontroller will execute a specific piece of code called an interrupt handler (see user_routines_fast.c). This interrupt handler will simply increment the global variables "msClock" and "Clock". High-level user code can then access these variables to create sophisticated state machines and highly accurate sequencers. We'll just keep the time.
The code can be found here.
Because I found MPLAB 6.3 so buggy, I updated to 6.4 (found here) which isn't compatible with the 6.3 project file format. Consequently, you'll need to update to 6.4 or create a new project with the project wizard if you want to re-build the code. Include all files in the .zip except ifi_library.lib. If that's too much hassle, I've also included the .hex file which IFI_Loader can use.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Last edited by Kevin Watson : 14-12-2003 at 17:00. Reason: Provide link to earlier message
Unread 17-12-2003, 15:14
FRC #2429
Re: EDU Demo Code: Real-Time Clock Using a Timer
I've updated the clock code to fix a minor timing accuracy bug. By request, I've created a version that includes tenths of seconds too. I've also converted the project files to version 6.30, making it compatible with the version of MPLAB that IFI distributes on the S/W tools CD. Enjoy. The files can be found here: http://kevin.org/frc.
-Kevin
Kevin Watson
http://kevin.org
The Unnoficial Constitution - A Real Inspiration sanddrag Team Organization 6 19-09-2003 15:40
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
How long should production time be??? archiver 1999 4 23-06-2002 23:16
real time chat SharkBite CD Forum Support 4 07-02-2002 21:22
