Need Good Cheap Gyro for Balancing Vehicle
I need a good cheap gyro/accelerometer/tilt sensor/ whatever you call it for my balancing vehicle project. It needs to be easily compatible with a BS2. I was thinking of using this one (or maybe two) Parallax sells http://www.parallax.com/detail.asp?product_id=28017 Will this work? How do I know what would be a good one or not? Thanks.
Re: Need Good Cheap Gyro for Balancing Vehicle
Anyone? I need to order this really soon. Thanks.
How cheap is cheap?
You can get the yaw rate sensors from Future that were discussed by Chris Hibner.
See this thread From that thread: Quote:
They are not exactly cheap. The ADXRS150EB (the one in a DIP package rather than the ball grid array, which is hard/impossible to deal with for most people) is $94 from Future Electronics. I have a recollection of a price of $75 or so from NewarkInOne.com, but when I went there to find it, I struck out. As to compatible with the Stamp2, you are more or less on your own. I feel pretty sure that you will struggle to do the calculations you are likely to have to do without a faster CPU, but don't let me stop you. Good luck. Joe J. P.S. You could always ask around on Chief Delphi for old FIRST gyros. Many teams never touch them. You may be able to find a bargain. JJ Last edited by Joe Johnson : 17-12-2003 at 14:26. |
Re: How cheap is cheap?
I have the acecelerometer you mentioned above. It works, but its a pain. I would recommend the ADXRS150 and the ADXRS300 gyros mentioned above. If you don't need much prescision, but need accuracy over time then i would point you to: http://www.acroname.com/robotics/par...7-COMPASS.html
Will the Memsic one Parallax sells work for a balancing vehicle application? It seems like it would be the easiest to use with the BS2 and also the cheapest. The ADXRS300 and ADXRS150 I can get for about $55 but I don't know how to use them with the BS2. The Memsic has sample code but I don't know if it will work. Does anyone else know?
Sorry, Sanddrag. |
