Go to Post By the looks, 1114 has already figured out both #1 and #2. They're still behind 71, who is just about done with their robot for the 2012 season, is getting driver practice for 2011, and is working on their robot designs for the 2013 water game. You're still way behind. - EricH [more]
Unread 20-12-2003, 14:02
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
EDU Demo Code: Encoder Interfacing Using Interrupts
I'm writing a motor controller that I intend to release in the future, but because of the interest in interfacing encoders lately, I've put together a small example that shows the best way I know to interface a quadrature encoder to the EDU robot controller. With this code, I've been able to track an encoder generating a few thousand counts per second. The code can be found here: http://kevin.org/frc.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 20-12-2003, 14:57
GregTheGreat's Avatar
GregTheGreat GregTheGreat is offline
GregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura aboutGregTheGreat has a spectacular aura about
Re: EDU Demo Code: Encoder Interfacing Using Interrupts
-Kevin
Very Kool.... This is definitely a great example of good programming.
Once again... Very Kool.
-Greg The Great
Unread 22-12-2003, 01:09
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Thanks!!
The more examples on how to use interrupts correctly and effectively, the better...
Unread 08-01-2004, 22:57
roknjohn roknjohn is offline
roknjohn is an unknown quantity at this point
Kevin,
Thank you for all of the great interrupt examples for the EDU controller. They have been extremely educational. I've been racking my brain all year to figure out a simple way to use an encoder that had a useful resolution. This looks like an elegant solution with the new hardware.
My question is this: How does this translate to the full-size controller? I didn't see any interrupt pins on it.
Would we have to use a timer?
Unread 08-01-2004, 23:14
FRC #2429
Originally Posted by roknjohn
Kevin,
Thank you. I'm glad you're making use of the code.
Yes, we'll have interrupts on the new FRC controller. The port b interrupts on the EDU-RC directly map to the first six digital inputs on the new controller (i.e., Interrupt 1 = digital I/O 1, interrupt 2 = digital I/O 2,... interrupt 6 = digital I/O 6).
-Kevin
Kevin Watson
http://kevin.org
