Go to Post There is almost always more than one solution to any engineering problem. One part of elegant design is picking the one that makes the most sense for a particular design problem, even if that means "breaking" some normally established "rules". - Jeff Pahl [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 20-12-2003, 20:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Keying a shaft
I am trying to create a keyed shaft, but I am not sure how you would go about doing it. I figured the easiest way would be to look at the face of the shaft and then draw the outline of the keyway, then cut it out, but it will not let me do that, or I am trying to do it wrong. I al also trying to do the same thing with gears, but I assume that would be the same process. Any help you guys have would be greatly appreciated.
Thanks,
Cory
2001-2004: Team 100
2006-Present: Team 254
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Motor coupling archiver 2001 19 23-06-2002 23:35
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
Connecting new gear to shaft? mnkysp6353 Technical Discussion 10 29-01-2002 05:12
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
