Go to Post You have not only joined a robotic competition, you will discover that you are becoming a member of a very large and wonderful family. The more years that you participate, the larger your FIRST family will become. - Car Nack [more]
Unread 21-12-2003, 20:59
alexrobotics alexrobotics is offline
alexrobotics is an unknown quantity at this point
Chiaphua HP?
We are trying to use the chiaphua motors for this year's competition and we know the free load rpm but we haven't found anything on the horse-power of this motor at any load. Do you guys know?
Unread 21-12-2003, 21:01
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: Chiaphua HP?
the CIM puts out about 300 Mechanical watts at 550 RPM. when powered at 40 amps and 12 Volts
Unread 21-12-2003, 21:15
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
Team Role: Teacher
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: Chiaphua HP?
according to this thread: http://www.chiefdelphi.com/forums/sh...ght=horsepower
Drill: .504
CIM: .4562
F-P: .1987 <-w/ GB: .121
Globe: .053
Van: .0889
Window: .0074
search before ya' perch
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 11-01-2004, 10:26
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Re: Chiaphua HP?
The Formula for any motor is Motor Power = 1/2 Free Speed X 1/2 Stall Torque
CIM Free Speed @ 5000
Stal Torque @ 2.2 N*m
The CIM motor would be 5000RPM/2 * 2.2 N*m/2 * 2 *PI/60 = 317 Watts
Unread 11-01-2004, 12:10
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Rookie Year: 1999
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
1/2 stall torque X 1/2 free speed only happens at ideal situation
Please note that this is the MAXIMUM amount of power your motor can output at the most ideal situation. If you gear your motor to move exactly at 50% of the free speed and output exactly 50% of stall torque, then you will output this amount of power at 12v.
Considering this is a CIM motor with a speed controller, as you are pushing on your joystick or whatever you are using to control your robot component, you will start out at 0v, then 2v, 4v, 6v, until 12v at a curve designed by your programmer. You want to watch out how much electricity you are giving the motor.
As soon as the load on your robot component increase, you will using more than 50% of the stall torque, and the amount of power output will change. Chances are, with all the robots out there trying to get control of big balls, pulling up the hanging bar, going up the steps, moving the goals, you may experiencing more force than you think you would.
So, gear your motor conservatively, and put whatever you can to help your device along so your motor stay as healthy as possible. Understand that at different combination of speed and torque, your power output will be different. Check the speed-torque curve. Be prepared to do a lot of testing to get the right configuration.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Matching Drill and Chiaphua sanddrag Motors 12 17-01-2003 11:23
Coupling the Chiaphua & a variable Drill output Jeff Sharpe Motors 9 13-01-2003 20:21
Chiaphua Spec Sheet Joe Johnson Motors 12 09-01-2003 16:01
Chiaphua gearing (Chippy and Bosch) honky Motors 3 31-01-2002 10:28
Pairing Drill Motors to Chiaphua Matt_White Motors 15 16-01-2002 13:15
