Linux with the PIC
I got the PIC with the C18/IFI working on Linux. What you need to do is install wine and install the MPLAB/C18/IFI software with wine. However, MPLAB isn't compatible with wine. Thus, here is a makefile using wine to do all your compiling and linking using the c18 compiler mcc18. I'll get more support later, but this allows you to compile the files in the terminal and use whatever editor you want. Then you can just run wine and send the files. I suggest getting the codeweaver trial office to install it, then just wine to manage it. 3AM gotta sleep have fun.
wget http://xp.scv.net/x2545/code.tar.gz tar -xzvf code.tar.gz cd code make #after wine is installed with c18 etc, don't forget to edit the Makefile to configure paths |
Re: Linux with the PIC
The IFI loader works on regular wine now?
It turns out, it copies, but it's corrupted and it won't go pass the Fault Status, but that goes away with same code in Windows. Working on script to do it.
| Linux | SteveC116 | 3D Animation and Competition | 22 | 25-03-2004 15:07 |
| Linux And Windows XP | Raven_Writer | Chit-Chat | 4 | 06-08-2003 18:53 |
| pic: Another pic of Team 930 | CD47-Bot | Robot Showcase | 7 | 25-02-2003 21:07 |
| RoboEmu for Linux (PBASIC emulator) | rbayer | Programming | 5 | 21-11-2002 21:08 |
| Linux file extensions | rbayer | CD Forum Support | 5 | 14-11-2002 23:04 |
