Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 03-01-2004, 01:58
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Re: Coefficient of Frictions
Originally Posted by mzitz2k
Joe,
Thanks for all your help! You mentioned Team 60 found the soft rubber cross hatched material had the best coefficient of friction, was this a tan color material that has been used more and more increasingly by teams. You're pit is usually close to Team 33's - is the material they use similar to what you are discussing?
I think it was this type of cross hatch (called "wedge top" in the McMaster catalog):
Though we have had good success with a 3 ply Neoprene "rough top" also from McMaster.com:
Both are on page 1081 of the current McMaster catalog.
For what it is worth.
Joe J.
Tread or Wheels? Jordan A. Technical Discussion 28 10-01-2002 04:05
