Go to Post Everyone should go look at the baby pics….it will make you feel better. - wendymom [more]
Unread 03-01-2004, 19:20
Matt Fultz's Avatar
Matt Fultz Matt Fultz is offline
Matt Fultz has a spectacular aura aboutMatt Fultz has a spectacular aura about
Pneumatic Layout (Does it work?)
If anyone could figure out if this verbal model will work, that would be great. If it won't, please say why it wouldn't power the pneumatic cylinder, or say if anything should be added or changed. I could not make a picture of this, so I am just stating all connections.
Compressor to a brass T fitting. The "stem" (vertical) part of the T runs to a pressure gauge, the other end is run to the resevoir. The resevoir runs out to another brass T where the stem runs to a quick connect fitting to run tubing to a double solenoid and the other end of the T runs to a pressure switch to shut off compressor. The tubing runs to the double solenoid and out of the d.s. to the pneumatic cylinder.
If more detail or more parts are needed, please tell me.
Thanks!
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
