Go to Post "The world is not idiot-proof. Pay Attention." - DonRotolo [more]
Unread 03-01-2004, 21:00
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
Rookie Year: 2000
rwaliany will become famous soon enough
Infra-red following eduRobot
Our team has created an infra-red following robot, this is basically an example if you want to use sensors and want to know how. The sensors are extremely sensitive and more than one sensor is on at any given time. Thus, the algorithm counts the sum of the last four signals, etc... see below.
Basically, if you have a remote control from any TV, you would simply point it and press any button faced towards the eduSensor robot and it will come toward you. The algorithm has proven to be 100% accurate and the robot never wanders off course unless you stop emitting the infra-red signal.
Sample of it working:
http://www.hartrobot.com/eduSensor1.avi
Tools needed: 2 multi-speed motors, 4 infra-red sensors, eduRC.
If you want the full source code, you can leave a message and I'll get it to you. Here are the changes:
Code:
//HartBurn Infrared follower:
 Four Sensors, Digital/Analog in pins 1-4
 1 - Front sensor
 2 - Right sensor
 3 - Left sensor
 4 - Back sensor
 Two motors, PWM output 1 and 8.
 1 - Right motor
 8 - Left motor
#define forward 1
#define left 2
#define right 3
#define spin 4
#define second 1000/17
#define NULL 0
typedef enum
   true=1, false=0
} bool;
typedef struct
   unsigned char value;
   int sensor;
   int last[4];
   int sum;
   int action;
} list;
list positions[4];
void add_value(list *ptr);
void sum_values(list *ptr);
int get_state(void);
void search(void);
// Init
  IO1 = IO2 = IO3 = IO4 = INPUT;
  Set_Number_of_Analog_Channels(FOUR_ANALOG);   /* First four pins are analog input */
  positions[0].action = forward;
  positions[1].action = right;
  positions[2].action = spin;
  positions[3].action = left;
//Misc functions
   int i = 0;
   for(i = 0; i < 3; i++)
      ptr->last[0] = ptr->last[i+1];
   ptr->last[3] = ptr->value;
   int i = 0;
   ptr->sum = 0;
   for(i = 0; i < 4; i++)
      ptr->sum += ptr->last[i];
int get_state(void)
   int i = 0;
   unsigned char min = positions[0].value;
   int state = positions[0].action;
   for(i = 1; i < 4; i++)
      if (positions[i].value < min)
         min = positions[i].value;
         state = positions[i].action;
   return state;
/* Locates infra-red signals, drives towards them. */
void search(void)
  static int timer = 0;
  int state = 0;
  int i = 0;
  /* Input signals */
  positions[0].value = (unsigned char) (Get_Analog_Value(rc_ana_in01) >> 2); // Forward
  positions[1].value = (unsigned char) (Get_Analog_Value(rc_ana_in02) >> 2); // Right
  positions[2].value = (unsigned char) (Get_Analog_Value(rc_ana_in03) >> 2); // Spin
  positions[3].value = (unsigned char) (Get_Analog_Value(rc_ana_in04) >> 2); // Left
  if (timer == 0)
     pwm01 = 127;
     pwm08 = 127;
  else
     timer--;
  /* All sensors are receiving full infra-red signal, don't do anything. */
  if (positions[0].value + positions[1].value + positions[2].value + positions[3].value <= 0x0F)
     return;
  /* Continue and output only if possible signals exist, input when no signal
       is 255, faint signal < 100, strong < 50, full == 2, short circuit == 0 */
  if (positions[0].value < 50 || positions[1].value < 50 || positions[2].value < 50 || positions[3].value < 50)
     printf("%d %d %d %d\n", (int)positions[0].value, (int)positions[1].value, (int)positions[2].value, (int)positions[3].value);
  else
     return;
  /* Recalculate signal continuity measures, lowest sum is most continuous */
     add_value(&positions[i]);
     sum_values(&positions[i]);
  state = get_state();
  if (state == forward)
     timer = 50;
     pwm01 = 55;
     pwm08 = 200;
  else if(state == left)
     /* Lag left using forward's timer */
     if (timer < 5) timer = 5;
     pwm01 = 55;
     pwm08 = 55;
  else if(state == right)
     /* Lag right using forward's timer */
     pwm01 = 200;
     pwm08 = 200;
  else if(state == spin)
     /* Spin long enough till another sensor is in range */
     timer = 20;
     pwm01 = 200;
     pwm08 = 200;
void Process_Data_From_Master_uP(void)
  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
  +search();
  Putdata(&txdata);
R
Can you use PWMs (Red or Blue) with the edubot controller? Dr.Bot Robotics Education and Curriculum 3 04-12-2003 23:51
Spike RED Pinout Venkatesh Electrical 3 31-03-2003 21:42
Victor control with Edurobot?? Bob Steele Motors 4 19-02-2003 12:48
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
EduRobot - Mini-Bot in action ECarlson Robotics Education and Curriculum 11 31-08-2002 09:51
