Go to Post Stop making me think so hard! :D - Chris is me [more]
Unread 04-01-2004, 15:01
mzitz2k's Avatar
mzitz2k mzitz2k is offline
Robotics Fiend
AKA: Matt Zitzmann
None #0302 (Mechanical Dragons)
Team Role: Student
mzitz2k will become famous soon enoughmzitz2k will become famous soon enough
Send a message via AIM to mzitz2k
Chiaphua Gear Box
(1) If one were to use a Chiaphua motor for the gear box, would it be necessary to support the end of the output shaft (from the motor itself). I have seen several other designs here on CD that have Chips as part of their gear boxes and I haven't seen any gear box that supports the end of the shaft. I tore apart a Chip and noticed that there were two bearings (one on each end), hence a third bearing would break Woodie's old law - avoid odd numbers of bearings in a line.
(2) Also, on many of these designs that I spoke of earlier, I have seen output shafts that continue past the gear box's aluminum plates. I assume teams are connecting a sprocket to these shafts, but just outside the gear box. So, my second question is: Is it necessary to put a third bearing in line (outside the gear box) so that the sprocket doesn't cantilever the shaft? Again, if the answer is yes, it would be breaking Woodie's old law.
(3) Thirdly, have teams found bronze bearings or the usual bearings best for supporting the shafts in the gear boxes?
Thanks
Matt
Team 302 - "The Mechanical Dragons"
Engineering Inspiration Award - Western Michigan Regional (2004)
Division Champions - Newton Division (2003)
Regional Champions - Great Lakes Regional (2003)
General Motors Industrial Design Award - Great Lakes Regional (2002)
Motorola Quality Award - Buckeye Regional (2002)
Regional Finalists - Buckeye Regional (2002)
Division Finalists - Newton Division (2001)
Regional Finalists - West Michigan Regional (2001)
chiaphua gear cluster Antonio Motors 31 26-01-2003 20:04
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
drilling that chiaphua gear ahecht Motors 8 06-02-2002 01:23
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
