Go to Post Mentor: How is that held in place? CAD Lead: Go to the hardware store and buy a bag of constraints and put the constraints on the robot. - Kenyow [more]
Unread 04-01-2004, 21:15
Jacob Morgan Jacob Morgan is offline
Jacob Morgan is an unknown quantity at this point
Another Question.
Hey guys i've got another question..
I've pretty much decided on the These two motors.
The only problem i've seen is the fact the casing on them is the ground. Can anyone tell me what woudl happen in the following instance.
Each motor will be on its own speed control, and battery. The only time this would pose as a problem would be when one motor is in reverse, and the other forward since the reversed motor's once positive now negative. vice versa.
Now this would normally create a series right? neg from one battery and positive of the other (both contacting the frame) my question is, will this affect anything? since the series isnt' actually being completed. The other neg is on a motor, and pos on the other motor, not giving either motor the full 24 volts from the two batteries.
Will this affect anything at all? or will it make a motor or both run in a series? or short something out?
Thanks guys hope i didn't confuse anyone as much as i am.
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
Naming question...... turbidum General Forum 0 11-01-2002 05:01
