Go to Post (middle school age) One time I had a truly awful day at school and came home crying. My mother's response? "Do you want to go to the build session tonight? It will make you feel better.." And it did. It always does. - rachelholladay [more]
Unread 09-01-2004, 16:56
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
Rookie Year: 2000
rwaliany will become famous soon enough
Linux: steps to program fullsize RC robot
Post here if you need help and this doesn't work.
Current site: http://ryan.scv.net/x2545/pic
Code:
Documentation IFI Linux PICloader setup Fullsize RC with MCC18 compiler:
Non-root setup (advanced users):
Same steps as "root setup"
 Additional steps
 edit ~/picloader/code/Makefile # change user directory to yours
 chmod permissions <device>     # on startup
 cp picloader /usr/bin          # cp picloader to binary directory as root
Gentoo (root setup):
cd ~/
wget http://ryan.scv.net/x2545/picloader/...der.0.2.tar.gz # get the file
emerge wine                        # installs package
wine                               # installs wine basic setup information
mount /dev/cdrom /mnt/cdrom        # pipe the cdrom to /mnt/cdrom
cd /mnt/cdrom                      # change local directory to /mnt/cdrom
wine MPLAB_C18.exe                 # start the install, install it to default directory c:/mcc18
cd ~/                              # change to home directory
(editor) ~/.wine/config            # add path
@ 77
- "Path" = "c:\\Windows;c:\\Windows\\System;f:\\;h:\\;z:\\"
+ "Path" = "c:\\Windows;c:\\Windows\\System;f:\\;h:\\;z:\\;c:\\mcc18\\bin;h:\\ifi-picloader\\code"
@ 90
- "Windows" = "win98"
+ "Windows" = "winxp"
cd ~/
tar -xzvf ifi-picloader.0.2.tar.gz # extract the file
cd ifi-picloader                   #
make                               # compile the Linux programmer for the RC
cd code                            # change to where all the code should be done for your robot
make                               # compile the code in the code directory
picloader FrcCode.hex <device>     # write program to serial device, usually /dev/ttyS0 com1
# Device samples
# Com1 = "/dev/ttyS0"
# Com2 = "/dev/ttyS1"
# Com3 = "/dev/ttyS2"
# USBSerial (pl2303) = "/dev/usb/tts/0"
Thanks,
Ryan Waliany
R
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Anyone looking for more program space? archiver 2001 13 24-06-2002 02:20
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
robot control emulator for default or other program CharlieWilken Programming 26 24-02-2002 02:36
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
