Go to Post If regolith ever makes a return, I will jump out of a window. - Oblarg [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 09-01-2004, 22:13
Unsung FIRST Hero
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Rookie Year: 1996
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Exclamation i-Gear Released
I released i-Gear(English) in the Gears library of First Cad Library. This i-Part allows you to define your own gear design so if you put in data that doesn't make sense (like a bore that is bigger than the OD of the gear) then it will blow up. I'll release a metric version and a version with hard coded "Boston Gear" specs after kick off.
I also posted a few other parts along with all of their variations. I'll get as many of the new kit parts as I can out over the next couple of weeks.
If any of you non-Inventor users need a particular spur gear generated, send me the specs and I'll post it for you.
I'll be at the Altanta Kick-Off ........
Ed Sparks
MECH TECH FRC-3959
Unread 10-01-2004, 16:32
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
Re: i-Gear Released
a bit off the topic... but mr. sparks are all the firstcad library parts made by u? or do u take submissions? i have the 2004 field pretty much done...but dimensoins will need treaking. i would be honored to help in any way
Unread 15-01-2004, 10:25
Unsung FIRST Hero
Rookie Year: 1996
Re: i-Gear Released
Thanks matt111 but I'm going to keep this site "In-House" for now. I'm thinking about opening things up for next year.
Ed Sparks
MECH TECH FRC-3959
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
