Go to Post Comments and Documentation: Use them! You would never believe how fast you will forget how something works, especially when things are flying at you so fast. Other/future programmers will understand what you did and why you did it. - BigJ [more]
Unread 09-01-2004, 22:13
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
ADC problems with C library and new code
Has anyone successfuly manipulated the ADC hardware directly? It appears that the C compiler function "SetChanADC()" doesn't work correctly. I have tried to set the channel manually but can't seem to get it to work correctly.
The PIC (and IFI) defines show the channel # shifted left three bits, but the 18F8520 data sheet shows them shifted only 2 bits. SetChanADC() doesn't shift the bits at all.
OpenADC() does the right thing with the channel, but I don't want the overhead...
Cheers!
The New and Improved FIRST CAD Library Ed Sparks General Forum 22 03-02-2007 18:03
