Re: Ohh Well another trans down the tube
yeah.. we've had a 2motor (drill/atwood) 2 speed transmission for a few years now, and we've decided to use it again this year.. some of the engineers didnt think it would be necisary, but after a whole bunch of *debates* the 2 speed finally won out.. ive got pics of last years atteched if anyone is interested
Two summers ago, my team (116) spent the summer developing a gearbox. It is a two motor, two speed gearbox with a weight of 10.0 lbs. We have posted documentation on it for other teams to use. This documentation includes blueprints, a parts list, 3D images, and other technical information. I will try to find where this is located, so that you may retrieve it at your convenience.
I'm not a physics major but I have designed and built a two motor two speed pneumatic shifting gearbox and competed with it in competition. I think the two motor system helps but I think it could be argued that that much power is wasted on a FIRST robot. with only 130 lbs of robot there is no way that you can transfer all that tourque to the ground. Your wheels will spin out before your motors will stall. I think using one motor per side and adding some sort of skirt or other mechanism to transfer the weight of another robot to the ground is the way to win the pushing match not adding more motors. what does everyone else think?
last year a few teams build wedges to give them a protective and pushing advantage as you pointed out
problem was some bots didnt handle being 'lifted' a little and were tipped over in shoving matches - and tipping another bot will get you disqualified. if you lift the side of the bot you are pushing against, all that does is transfer most of the weight to its rear wheels - they can still push back just as hard, but you have altered their center of gravity, and there is a good chance you will tip them. |
| Has any one stuck a drill motor in the FP trans? | Lotownvw | Motors | 15 | 21-04-2003 23:57 |
| Aluminum Tube Source | archiver | 2000 | 3 | 23-06-2002 22:32 |
