Go to Post A 823543:1 reduction should be fine if you ever need to pick up a truck...or a house. - Tim Sharp [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 10-01-2004, 21:47
SteveC116's Avatar
SteveC116 SteveC116 is offline
SteveC116 has a spectacular aura aboutSteveC116 has a spectacular aura about
2004 Codec Requirements
If you have read the guide for this years animation competition you will see that they have specifically said no to DivX:
Acceptable Codecs: DV-NTSC and Cinepak. Do not use DiVX or any other non-standard Codec
Am I the only one out there who finds this to make no sense? Cinepak? Cinipak was developed to play small movies on the 386 and 030 systems from a single speed CD-ROM drive. Cinepak is a good choice if you want your movie to play on a wide range of systems - but I fail to see why it is chosen over codecs like XviD and DivX.
Am I wrong in remembering that people were allowed to use DivX last year? Last year Lev was the one in charge of converting the rendered targas into the appropriate movie file so I'm not sure - but I believe that we used the DivX codec.
Also, as some of you may remember, our animation experience at the competition was horrible. The VHS made with 116's animation looked similar to that Pokemon episode which caused seizures in Japan. If this is because of the DivX codec, I don't see why we should be penalized because the person in charge of the tape can't convert these movie files correctly.
Or maybe I'm totally off. If somebody could respond who understands codecs better than I do that would be appreciated. What exactly is this DV-NTSC format? Is it any good? Am I not giving cinepak enough credit?
Basically what I'm asking is: what codec do you all recommend we should use to, ignoring file sizes, create a high quality animation?
*Guarana Induced Happiness*
Steve Cohen
Team 116 Animation Captain
http://stevecohen.blogspot.com
Unread 10-01-2004, 23:14
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
Re: 2004 Codec Requirements
yea this seems unneccesary. my view is if it plays, let it in. our animation experience was even worse. with 3 days till it had to be mailed, we left our mentor to burn the CDs and ship it. well we get to st. louis and then we discover we arent on the judging sheet. ends up he sent 2 discs, one was corrupt, and the other was blank...and the judging was bad, with lots of crowd noise and stuff
Unread 10-01-2004, 23:43
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Rookie Year: 2000
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Just encoded it into DV-NTSC 25. You definitely have the space for it on a CD. DV produces the best quality video. It is even better quality than a DVD (MPEG-2). It makes no sense to use an MPEG-4 variant for something that is so short.
Unread 11-01-2004, 01:11
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Can you use uncompressed, sice it is no codec?
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 11-01-2004, 10:51
SteveC116's Avatar
So DV-NTSC is basically the same thing that DVDs are encoded in? If thats the case then I think that this really isnt an issue. If it fits on the CD and the quality is great, then I have no quams using it instead of DivX.
Steve Cohen
Unread 11-01-2004, 11:27
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #6013 (Robowolves)
Steven Carmain will become famous soon enough
I think half the problem with Divx is the advertisement in the right corner. FIRST would have a hard time releasing versions of "Commercials" because of licensing agreements with Divx.
I also think that MPEG-4 codecs are fine for the animations. I change MPEG-4 to DVD format a lot and the movies are still fine.
2016+ - Team 6013 Lead Engineer
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 11-01-2004, 17:07
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
I am not sure about this one First of all, the logo is easy to get rid of (its just 1 checkbox in the config). And FIRST could decomress the video if they wanted to use it in an ad or something.
Unread 11-01-2004, 13:28
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Steve -
DV/NTSC is literally "Digital Video / National Television Standards Committee." It is the format used in high-end consumer digital video cameras and recorders. It is a higher-end, high-quality compression and encoding method (particularly in comparison with older encoding standards such as Cinepak or MPEG-2). I think you will not have any problems with it (certainly none like last year), and will like it.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 11-01-2004, 18:16
SteveC116's Avatar
Steve -
-dave
Thanks Dave! Why is cinepak even mentioned then? It is pretty outdated isn't it?
And congratulations on Mars! I think I read in the Post that a bunch of Nasa engineers are going to Europe to party - is this true?
Steve Cohen
Unread 11-01-2004, 18:29
thegrug thegrug is offline
Animator
AKA: Zack A.
#0084 (Chuck 84)
thegrug is an unknown quantity at this point
Send a message via AIM to thegrug
DivX & Xvid=MPEG-4 modified in some way
Video CD & Super VCD=MPEG-2
DVD=MPEG-1
DV-NTSC=Digital video codec originally used for digital video captures
Cinepak=extremely outdated
I prefer MPEG-4(but not DivX or Xvid) personally. Cinepak shouldn't even be used anymore because of it's sub-MPEG quality.
Unread 11-01-2004, 19:01
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
DVD=MPEG-1
actually, DVD is mpeg-2 and vcds are mpeg-1.
Where has all the fun gone?
Unread 11-01-2004, 19:22
dragonpaulz's Avatar
dragonpaulz dragonpaulz is offline
4 P3r$0n
AKA: Paul Shapiro
#0555 (Team 555)
dragonpaulz is an unknown quantity at this point
Send a message via AIM to dragonpaulz
I am a big fan of divx. I encode most of my video files in it accept when intended for the web. Divx is good quality and great on compression. Plus divx is so widely used that FIRST should consider it a standard coded. This stinks.
Team 555 - Montclair High School
Trust, Love, and Magic
WebMaster of MontclairRobotics.org
Unread 12-01-2004, 00:50
SteveC116's Avatar
Yeah. What got me was that they said DivX wasn't a standard codec.
Steve Cohen
Unread 12-01-2004, 02:03
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
DivX is not a standard codec in that 90% of computer users have never heard of it and don't have it. It's sad but true that if Windows Media Player can't play it out of the box, it isn't a standard codec.
  #15   Spotlight this post!
Unread 13-01-2004, 22:47
djcapelis's Avatar
djcapelis djcapelis is offline
Fried Manic Custard
None #0675 (Geeks with Power Tools)
djcapelis will become famous soon enoughdjcapelis will become famous soon enough
Send a message via ICQ to djcapelis Send a message via AIM to djcapelis Send a message via Yahoo to djcapelis
If only everything could play as much as mplayer...
too bad most of the codec support has to be illegal and all...
"I have more friends than enemies, I'm working to resolve the issue."
2004 IRI (Indiana Robotics Invitational) Chris Fultz Off-Season Events 147 24-04-2007 23:33
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
2004 Robot Controller CNCBoy461 Electrical 18 02-12-2003 16:36
2003 Finals Video and 2004 Request soap108 General Forum 2 13-09-2003 01:02
