Go to Post NEMO is a virtual organization with a virtual headquarters and virtual bank account. - KathieK [more]
Unread 11-01-2004, 12:55
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
Re: InfraRed = gps ?
Ohhh. Boooo..... I don't like trig.
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
Unread 11-01-2004, 13:21
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Originally Posted by mightywombat
ok. So you'd have one beacon tracking each of the different types by how often they recieve envelopes? How exactly are you going to figure out the distance from the emitter? Will the signal be recognizeably weaker the farther you get from it?
This is the sequence of events within the beacon state machine:
1) The type-0 beacon is allowed to flash for 1ms. As the carrier frequency is 40KHz, this means the LED will flash on and off 40 times.
2) A delay of 3.5ms where both LEDs are off. This allows reflections to die off before...
3) The type-1 beacon (on the other side of the field) is allowed to flash for 2ms, which means the LED will flash on and off 80 times.
4) Another 3.5ms delay is inserted where the LEDs aren't flashed before the state machine starts all over again at #1 above.
If you add up all of the periods (1ms + 3.5ms + 2ms +3.5ms), you'll see that the total time needed to flash the beacons is 10ms, which means the beacons flash at a 100Hz rate.
You can calculate your distance and angle to the beacon by using a little trig (exercise left to the student ).
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 11-01-2004, 14:02
AKA: Bill Rosemurgy
OK. That makes alot of sense and is actually pretty cool how it works. Thanks for explaining it.
www.team857.com
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
just wondering..(sensors) JasonStern Electrical 14 08-05-2003 00:16
Autonomous Mode Strategy Brian48216 Programming 27 23-01-2003 14:47
sensors George Technical Discussion 15 08-01-2003 14:39
GPS Robot K. Skontrianos General Forum 3 11-05-2002 00:32
