Nesting Interrupts - is it possible?
Can the PIC nest low interrupts? I.e. can I re-enable interrupts while in an interrupt handler and have the chip do the right thing?
I actually have a good reason for doing this, but I suspect the chip can't handle re-entrant code. Thanks In Advance for your wisdom. |
| EDU Demo Code: Encoder Interfacing Using Interrupts | Kevin Watson | Programming | 4 | 08-01-2004 23:14 |
| Interrupts Questions | mightywombat | Programming | 0 | 03-01-2004 14:50 |
| Problem with interrupts on the PIC | Mike Betts | Programming | 7 | 16-12-2003 21:26 |
| Interrupts on the EDU-RC? | Andrew | Programming | 3 | 13-11-2003 23:16 |
| New Controller Specs Posted | Jnadke | Programming | 58 | 05-10-2003 08:18 |
