Go to Post At this point I think I've absorbed more aluminum into my blood than the iron that was already there. - hectorcastillo [more]
Unread 11-01-2004, 10:47
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Unhappy CIM Motors to pull up Robot
I was considering using the CIM as a winch motor for the pull-up bar.
If our 130 lb. robot was directly under the bar and was pulling up from the center of mass, say 12 inches off the ground it would take a maximum torque of 130 lb*12 in = 1560 in-lb.
To keep the motor happy we will keep the load reflected back to the motor between 20-50% of Stall Torque.
CIM Stall Torque = 2.2 N*m which is 20 in-lb.
Running the motor ar 40% Stall Torque gives us Working Torque =20 in-lb*.4 = 8 in-lb
so Gear ratio for CIM woul be 1560 in-lb/ 8 in-lb = 195/1
If I am right, I am looking at too big of a gear reduction to make the motors work.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
