Go to Post The best defense is a good offense, never back down - Nawaid Ladak [more]
Unread 11-01-2004, 15:32
Gabriel Gabriel is offline
#1409 (Fightin' Llamas)
Gabriel is just really niceGabriel is just really niceGabriel is just really niceGabriel is just really nice
Send a message via AIM to Gabriel
Re: IR Sensors- will they attack hot Chiaphuas?
Thank you for pointing this out! I don't know the answer, but
at some point I'm definitely going to ask the filmmaking people at my college to bring in some cameras so that we can test this.
This is my first year as a team leader and I feel a little like the guys on Apollo 13. There's a line from the movie where one of the astronauts (Swaggert I think) is concerned that they will overshoot the Earth. Lovell replies "there are about 1000 things that have to happen for us to get home. We're working on number six, you're worrying about number 520." Its just one more item on the giant list of things to worry about
Currently: Team Leader - 1409
2001-2003 Founding Member Team 782
2003: New England Regional Winners
2003: New England Regional Xerox Creativity Award
2003: Newton Div. Semi-finalists
2000-2001: Team 508
Unread 11-01-2004, 15:44
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
Rookie Year: 2000
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
One other thing I've thought about. What about the Night Shot on some camcorders such as Sony. Are those IR devices? Even though you wouldn't be using it at a competition, could someone use it to knock a robot off it's course?
Unread 11-01-2004, 15:50
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Rookie Year: 1999
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
To put it simply THE INFRARED SENSORS WILL NOT DETECT ANYTHING OTHER THAN WHAT THEY HAVE BEEN DISIGNED FOR! ie. AN INFRARED EMITTER EMMITING AT THE FREQUENCY THE INFRARED DETECTOR HAS BEEN SET AT. I worked for 3/4 years designing and programing a pinewood derby racetrack finishline that uses infrared. We have not had any problem with extra light or other types fo thigns that interfere.
Unread 11-01-2004, 15:59
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
As these sensors on the robot will be much more receptive (as they're designed to seach a wide area for the beacon) I think they would be much more prone to interference (I remember at the FLL Competition there was trouble with all of the people downloading programs with IR to the Mindstorms at the same time and accidentally downloading over other teams' programs and the overhead lights interfering somehow) but since these detectors are designed to pick out a specific pattern, I think the interference will not be a problem unless someone in the crowd has a beacon (since we're to be given the specs for a beacon so we can make one for testing).
Also, since picking out the proper pattern of a beacon is a programming thing, I see the potential for someone to make a custom beacon and program their autonomous to follow that around so someone could remotely control their robot during the first 15 seconds, but I think we're just going to have to trust in GP that no one will do that.
Unread 11-01-2004, 16:37
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
It depends on the quality of the sensor really. I have experimented with building a LIRC-style universal IR receiver once and I can say that some detectors are actually affected by direct sunlight and fluorescent lights. Others are not affected as much. However, even if this does happen, the demodulated data is garbage, and will never be equal to the signal sent out by the beacon. So the robot will more than likely never consider a camera or a hot motor a beacon. However, strong interference may not allow a bot to recognize a beacon. This should not be a problem, however, since the playing field is usually quite dark.
Unread 11-01-2004, 16:51
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Team Role: Leadership
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
if it is a problem, you can get some aftermarket IR sensors that give back an analog signal, not just YES/NO. Then you can figure out what is strongest and most likely the beacon. And if you have a good programmer, with sensors attached to servos, he can make the bot check to make sure the IR it is detecting is comming from the right direction relitave to your starting position.
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 11-01-2004, 17:03
Greg's Avatar
I dont think this is possible. As has been said before, the signal is modulated. It is not just a "light on/light off" thing. The beacon is likely sending out modulated binary data, and the receiver gets the pulses, demodulates them, and then the software compares the binary signature. This is how a TV remote works. An analog detector would just get the average brightness of a pulsating source. Of course, all of this is unconfirmed - I have not seen the code yet and all the IR stuff is missing from our kit
Unread 11-01-2004, 17:06
AKA: SonKenshin
ahh, good point. I'm used to constant signals, but who knows? I think some experimenting is in order. Maybe some interrupts to collect the strength for 2 ms... hrmmmm
-Kesich
Unread 11-01-2004, 17:42
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
Wouldn't these things be as realiable as the sensors from last year we used to detect the reflective tape? I think they worked the same way.
Unread 11-01-2004, 17:54
AKA: SonKenshin
Didnt those use the visible light spectrum? And the light sensors projected, whereas the IR sensors just pickup, so there really isnt the chance of seeing reflection when there isn't one. I went straight dead reckoning, though. Getting to the top of the ramp and hitting boxes in 5 flat seemed better to me. Anyways, in the line vs IR arguement, i'd say IR because you can see the IR from anywhere. The line, on the other hand, can get smugged up, lost, and once you are done with it, the sensors are useless. Ir can triangulate though.... hehehe
-Kesich
Unread 11-01-2004, 17:57
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
The signal from the beacons and receivers probably resemble the signals from a television remote. I have never encountered any interfernce from body heat on those things.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 11-01-2004, 18:00
AKA: SonKenshin
Wouldn't that be funny. Walk by the TV with a candle and the tv turns on, mutes, unmutes, cranks the volume, then hacks the cable box and gets you free PPV for life. Heheheh :-D
-Kesich
Unread 12-01-2004, 10:29
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
OK,
Before you guys get too crazy, the IR emitters generate energy in the same area as heat but have one distinct difference. The emission will occur as 40kHz pulses for varying lengths of time. That is, bursts of 40kHz modulated IR energy. The night illuminators on cameras are just that, steady state, non modulated sources the same as hot bodies. The IR camera range finders and remote controls use modulated IR emitters at different frequencies so there should be no real problems if you keep in mind that you are looking for a 40kHz modulated source. The bandwidth of the IR is not 40kHz but likely is much wider than that since the bandwidth you are measuring is near visible light.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-01-2004, 12:26
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Originally Posted by Al Skierkiewicz
OK, Before you guys get too crazy...
Too late .
Yes, as Al correctly (again) points out, the Vishay TSOP4840 sensors that are included in the kit and also used for the kick-off demo specifically discriminate against these type of energy sources. They also discriminate against non-modulated 40KHz sources. I've put a link to the data sheet here: http://kevin.org/frc. The modulation scheme is discussed in this thread.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
  #15   Spotlight this post!
Unread 12-01-2004, 13:35
Joe Beynon's Avatar
Joe Beynon Joe Beynon is offline
i dont post much
AKA: Shyywkiwk
#0190 (Gompei and the Herd)
Joe Beynon is an unknown quantity at this point
Send a message via AIM to Joe Beynon
this is something that i asked about at the main kickoff because of the fll problem. the guy told me that he tested the ir sensors with 5 cameras that were said to have problems with the fll bots and none of them caused interference. he also mentioned that these ir sensors are the type used in high-end stereo equipment and the only thing to possibly worry about would be a flickering flourescent bulb.
what type of sensors are good and convenient magical hands Programming 7 04-01-2004 23:04
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
HURRY......Registration for FIRST ATTACK AT MERRIMACK is ope archiver 2000 2 23-06-2002 23:20
How do people get hot motors? archiver 2001 11 23-06-2002 22:24
HOT dishes up Animation Class archiver 2000 0 23-06-2002 22:00
