Go to Post FIRST: Making women's hair grow, and mens hair fall out. - Ashley Christine [more]
Unread 11-01-2004, 16:46
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
How Does a Winch Work?
I have searched far and wide for an answer to this question and I can not find it. Does a winch, more specifically a small electrical winch, use worm gears/spur gears/helical gears/other types of gears in order to lift the heavy loads that winches lift. Any information would be very helpful, How Stuff Works does not have any info, and that is usually where I fin dall the info I need. Thanks.
Aaron
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 11-01-2004, 18:03
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Re: How Does a Winch Work?
Im really not sure about what gears they use but they generally have some method of locking the gearing in place. Usually they use a rachet to lock the gears and to ensure that the items do not fall down.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 11-01-2004, 18:09
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
I believe they ratchet, with the motor usualy mounted parralel to the axis of the spool
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 11-01-2004, 18:33
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
Rookie Year: 2000
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
In 2000 we had a "wench" on our robot to pull the bot off the ground while hanging on the bar. I have a really good picture of it but I cant find it. When I find it i'll post it.
Unread 11-01-2004, 18:34
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Rookie Year: 2000
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
What you are trying to think of is a Ratcheting Winch.
A winch itself is very simple, defined as "A stationary motor-driven or hand-powered machine used for hoisting or hauling, having a drum around which is wound a rope or chain attached to the load being moved."
In our case, a Stationary motor-driven machine used for hoisting, having a drum which is wound a rope or chain attached to the load being moved.
A very useful site for information on winches (and a few other things) is:
http://pergatory.mit.edu/2.007/hando...c.html#winches
It also has an excel file for calculating data about the winch using real values from the motor.
A ratcheting winch however is very slightly different. It has something to ratchet along the gears
Note the shape of the ratcheting gear. When turning clockwise, the gear pictured will lock into the two pieces that ratchet along the gear. when turning counter-clockwise, the two pieces will "jump" to the next tooth. This is a means for safety and preventing slipping.
The effect of this can however be replicated without a ratcheting gear. There is more than one way to lock a gear box.
Unread 11-01-2004, 19:26
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
The van door motor has a worm gear built onto it. The thing about worm gears is that they cannot be backdriven, so it will accomplish the same thing that a ratchet would . . . except you can reverse direction with it, which you could not do with a ratchet unless you had a servo-powered release mechanism.
I don't know the specs for the van door, but I would assume that it has enough torque after the worm gear transmission to directly power a winch that can lift 130lbs . . if the spool diameter is small enough, anyway.
I'll look into that.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 11-01-2004, 20:36
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
The van door motor can be back driven unless the bearing screw (at the end of the worm gear) is tightened quite a bit. The problems with doing this are:
1) You lose power output by tightening it
2) It wears out and you have to keep tightening it to keep it from backdriving
Plus it might still back drive if it sees excessive force.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 12-01-2004, 20:11
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Also, if you're worried about keeping a motor from slipping (such as when the power gets cut at the end!) you could use a little pneumatic piston to lock something in place. If you were pulling in a cable on spindle like thing (i'm bad at the right names, forgive me) then on the side of that you could have ridges (think raised spokes) and then all you have to do is fire the piston into the side of the thing to lock the spindle in place. As long as you set up the pneumatics right, it won't move when the power gets cut.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 13-01-2004, 12:07
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Rookie Year: 1998
Adam Krajewski is on a distinguished road
And when it wears out, no amount of tightening will do you any good.
During the summer of 2000, I did a study on the brakes. What they are exactly is a set screw (did someone inhale?) with a spring mounted 'brake pad' on the end. When you tighten it, you force the 'brake pad' onto the side of a plastic (final drive?) gear in the motor. This pad will eventually wear down and break. At that point, tightening it will do no good, as it is just a tapered end of a set screw with a hole in the middle against hard plastic. I have pictures somewhere of various van door motor brakes, but I can't seem to find them right now.
However, the bottom line is the brake should really only be used to get rid of very minor problems with backdrive. In '99, we used a van door as a winch motor to raise the lift carrying floppies over 8 feet and friction plus the brake kept the lift in the air without a hitch. In 2000 we tried to do the same thing, burning up brakes in the process on the motor that drove the shoulder of our arm. The final solution I came up with was to use a PD control system for the arm, so that 'sag' during a match didn't matter because the motor always ran to keep it in the right position, something it could do easily for 2+ minutes.
I would suggest something along the lines of what generalbrando said, and using a pin to stop the drum from rotating or perhaps some type of one-way action with a release like what rachet straps and come-alongs use.
"My favorite programming language is solder."
- R A Pease
Unread 11-01-2004, 19:38
Drew Hopman's Avatar
Drew Hopman Drew Hopman is offline
Last Resort
FRC #0801 (HorsePower)
Drew Hopman is a jewel in the roughDrew Hopman is a jewel in the roughDrew Hopman is a jewel in the rough
Send a message via AIM to Drew Hopman Send a message via Yahoo to Drew Hopman
Re: How Does a Telescoping arm work?
While we are on the topic of how things work… Does anyone know how telescoping arms work? I had seen last year team 890 had a telescoping arm but I can’t figure out how to get it to work. Please help me.
Drew Hopman
Team 801
Unread 11-01-2004, 19:46
#1067 (SLUH)
Drew Hopman
Team 801
heh, you must have the same idea we do.
Ok, telescoping arms.
They are relatively simple, and this idea on making one is just something that hit me in the face while I was thinking about it. Call it intuition, or whatever. There are probably better methodes, but here goes:
You have the man (non moving) stage of you arm, right? you make the secondary (moving) stage of your arm capable of sliding up and down the main stage. Now, at the TOP of the main stage, attach a roller chain sprocket, a small nylon one with a built in bearing would probably be best on weight considerations. Now, run a chain (you can use really small chain for this) over the sprocket and anchor it at the BOTTOM of the secondary stage. Now, with the other end of the chain you can attach a motor, so the motor can real in the chain. As it does this, the secondary shaft is forced to slide up the main shaft, and you have a powered, telescoping arm. You can make the chain complete the loop if you want more control (I.E. you attach the secondary stage to one link in a continuos loop of chain . . that loop is your main stage.
You can expand this into a three stage arm if you add a sprocket at the top and bottom of the secondary shaft . . so the chain goes over the main shaft's top sprocket, under the secondary's bottom sprocket, over the secondary's top sprocket, and is anchored to the bottom of the third stage.
Another simple design I saw last year is using your elastic tubing to load your telescoping arm, and you could pull a locking pin out allowing the elastic tubing to extend the arm. You can't retract it, though.
Pneumatics could work for a short one, but I'm currently working on an inventor design of my chain one.
Unread 11-01-2004, 20:05
Last Resort
If you come up with something in inventor i would liket to see it. Thanks for the help.
Drew Hopman
Unread 11-01-2004, 21:42
#1067 (SLUH)
Drew Hopman
I'm working on it. Maybe I'll have it finished in a day or two.
It will be pretty rudimentary, I'm relatively new to inventor.
Unread 11-01-2004, 21:48
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
25's made a 12' telescoping arm in 2000. I attached a picture. If you have any questions, PM me.
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
  #15   Spotlight this post!
Unread 11-01-2004, 20:09
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Team Role: Teacher
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
telescoping arms take a look at this.
We use a push pull system. this system is always under tension. we we 14' with this arm in 2001
http://www.valleytech.k12.ma.us/robo...1Robot2001.jpg
went down to 17"
http://www.valleytech.k12.ma.us/robo...Bridge2001.jpg
In 2000 we use a telescope system that will go in both direction with a lot of power this one went as high as 10'
http://www.valleytech.k12.ma.us/robo...s/roboti86.jpg
http://www.valleytech.k12.ma.us/robo...s/roboti87.jpg
with a system like this you only tighten one nut to put the whole system into tension. this might look big and heavy but this telescope was made with thin alum. and light rollers. this only wieghed 15 lbs just the telescope part
I will say we have something even better than this.
Problems of the mind... effecting work Gadget470 Chit-Chat 20 18-11-2003 11:56
Edit doesn't work on original title posts??? Elgin Clock CD Forum Support 6 12-03-2003 17:30
Who knows how the motors [I]really[/I] work? Wetzel Chit-Chat 5 13-02-2002 21:50
Back up your work! Maddie N Chairman's Award 3 13-02-2002 06:16
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
