Go to Post when I was a ball setter at PARC one year (6th grade?). As soon as I saw what High school students could do with thier own two hands and how they mingled with industry, I knew, at that moment, it was for me. - henryBsick [more]
Unread 11-01-2004, 20:06
Jack21 Jack21 is offline
Jack21 is an unknown quantity at this point
Question Help! My 2003 Bot compressor won't shut off
Ok, I know the game for 2004 is on, but we need our old Bot operable for fund raising etc.
The Bot was working fine unti (I think) somebody tinkered with the default program. Now all systems still work, but the compressor won't shut off at 120 psi. I have swapped out the spike, the 3 wire cable, the fuses etc.. checked the cut off switch cable for breaks.( repaired this cable with almost all broken strands at connector end of cable). When pressure hits 120 psi the switch shows the circuit opens.( when checked with an ohm meter at the connector that attaches to the Robot controller).
Now I'm not even sure where the cut off switch is supposed to be connected to the Robot controller. What pins should I be connected to on the controller. any other help would sure be appreciated. Hadn't counted on wasting time on this old Bot when we need to devote energy to this years machine.
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
Image Discuss: Rookie Team 1108 w/ 2003 Bot HYO CD47-Bot Robot Showcase 2 07-04-2003 23:37
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
pic: RAGE Bot 2003 in action CD47-Bot Extra Discussion 8 30-03-2003 00:29
