Go to Post but eventually it seems that we realize that there's an I in FIRST, and the I stands for Inspiration, not for "me" - MrForbes [more]
Unread 11-01-2004, 22:05
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
compressor
so I got very dissapointed this year to see that veterans don't get a new compressor, so does that mean that we reuse our old compressor. I checked the rules, an it only says we can reuse solenoids and cylenders, and it doesn't mention that vets don't get a compressor. I hope it doesn't mean that vets are forbidden from using pneumatics!
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 11-01-2004, 22:14
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: compressor
It would be safe to assume that we can use our old compressors, since not being able to use pneumatics would be unfair to most of the teams.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 11-01-2004, 22:15
briholton's Avatar
briholton briholton is offline
AKA: brian holton
#0752 (Gods of Fury)
Team Role: Coach
Rookie Year: 1997
briholton is on a distinguished road
Re: compressor
i believe i read that rookie teams got new compressors and vets use old one to save space and money in kits.
Unread 11-01-2004, 22:18
resident insomniac
Team Role: Student
Re: compressor
cool, thanks... I hope it still works...
team motto:
AFLAC 2002
Unread 12-01-2004, 13:41
resident insomniac
Team Role: Student
Re: compressor
I wonder, would it be within the rules to purchase a different compressor, say a better one, that still operates on 12V DC, and can withstand 120 + PSI?
team motto:
AFLAC 2002
Unread 12-01-2004, 21:31
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: compressor
A simple No. You can purchase the same one.
Kevin Li
596 - Sciclones
Unread 12-01-2004, 21:39
briholton's Avatar
AKA: brian holton
Team Role: Coach
Rookie Year: 1997
Re: compressor
and, you are limited by the rules in pressure neway........
Unread 13-01-2004, 12:50
Fred Hord Fred Hord is offline
Fred Hord is on a distinguished road
Re: compressor
Veteran teams are suppose to use their old compressor.
Unread 15-01-2004, 00:01
resident insomniac
Team Role: Student
Re: compressor
any opinions on super glue or solid epoxy holding a hairline crack in the release valve port of the compressor? I plan to use it for a display board at 60 PSI.
team motto:
AFLAC 2002
Unread 16-01-2004, 00:28
resident insomniac
Team Role: Student
Re: compressor
it held at 60 PSI! it is confirmed now that simple super glue from the cvs can repair a split valve in a compressor.
team motto:
AFLAC 2002
Unread 16-01-2004, 19:23
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Rookie Year: 1999
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Re: compressor
Just in case your superglue fix doesn't work out Thomas(supplier of the compressor) does sell rebuild kits and replacement parts for these compressors. There is another thread that covers parts for the Thomas compressors.
Just an obvious word of caution from someone who works with pneumatics everyday- if a fitting, connector, hose, valve, ect. cracks or gets damaged some way its best to depressurize the system and replace it ASAP. Wether the part is plastic or metal glueing it or taping it isn't a permanent fix and since the part will handle various degrees of internal pressure and possibly getting jolted around from externally the part can fail without notice either by blowing a high stream of air and/or pieces of the part and in the case of a hose not tied down, whipping around violently. Even 60# (about 4 bars) is enough to launch broken pnuematics parts several yards. I know this might have seemed like "fatherly advice" but when working with ANY pressurized system you must be careful with it. Pnuematics are a lot of fun to work with and let's all keep it that way.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 16-01-2004, 20:18
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: compressor
Shouldn't your team have compressors from 2001 and 2002 as well?
Kevin Li
596 - Sciclones
Unread 16-01-2004, 22:43
resident insomniac
Team Role: Student
Re: compressor
well the 2001 compressor has dissapeared, and the 2002 compressor is still in that bot which is on display at one of our middle schools, so they can use it. and as to compressor burst, I will have some left over lexan when the frame is done, so I can encase it as a preventative.
team motto:
AFLAC 2002
Unread 17-01-2004, 00:15
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Re: compressor
My suggestion to you, switch the 2002 compressor with teh borken one, it won't pass inspection if it's borken.
Kevin Li
596 - Sciclones
  #15   Spotlight this post!
Unread 17-01-2004, 08:22
resident insomniac
Team Role: Student
Re: compressor
I already have gotten a new compressor, but I'm now integrating the old compressor into a display board to explain to new members exactly how pneumatics works.
team motto:
AFLAC 2002
Problem with compressor Nick R. Pneumatics 3 21-02-2003 10:51
Air compressor never shuts off Carl Owenby Pneumatics 4 08-02-2003 23:34
compressor questions Greg Needel Pneumatics 2 29-01-2003 16:58
compressor? BBFIRSTCHICK Pneumatics 11 22-01-2003 07:12
programming the compressor archiver 2001 4 23-06-2002 23:19
