Re: If you would "pull-up"...
The team I was on in 2000 (Team 49) also used the 2 van door motors to lift our bot in 2000.
We were under the impression that worm drives cannot be backdriven so we were a little disapointed to see that when we turned the power off after lifting, our robot slowly settled back to the ramp. We ended up having to make a possitive clamping mechanism. MattB |
So, if you are using the van door motor to lift your bot, you may want to design a locking mechanism. That is exactly what we did at 2000 when we used them to power a big arm that lift the robot body off the ground. Otherwise it will slip back down. |
Fisher Price motors, I believe, can handle the task.
what we've got in the works for this year is a 2" bore pneumatic tube on a double solenoid. of course, its not neccisarily a motor, but it's what we're counting on.
| Balancing | archiver | 2001 | 15 | 23-06-2002 23:51 |
