Go to Post The best [fundraiser] that we did was our various little things this year, such as calanders and other things. The worst is not doing one at all. - Joe Matt [more]
Unread 12-01-2004, 10:54
Chopper_Dave Chopper_Dave is offline
#0999 (CRASH)
Chopper_Dave is an unknown quantity at this point
Question Coupling the drill motor with out the 15 tooth gear
I would like to couple directly to the drill motor shaft without using the bosch planetary reduction and also without using an additional gear stage outside of our transmission. Has anyone removed the 15 tooth pinion gear from the drill motor and attached a hex coupling or some other type of coupling onto the drill motor? How did you do this and what type of coupling did you use
Thanks for the help!
Unread 17-01-2004, 01:06
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Re: Coupling the drill motor with out the 15 tooth gear
Well, it looks like you don't want to use the .7 module gear on the motor, or the transmission that comes with it, so you can do a few things. Some more eccentric than others...
You can remove the pinion with an arbor press and press on a new gear
You can mill off the teeth (very difficult to do) and key the remains, and put something on it using the key.
Yea.. what most teams do is just use another .7 module gear to mesh with the drill motor's gear, and then attach another type of gear to that one. This makes life a lot easier. But there are also many teams that just press the gear off and put on a new one, so their entire transmission can use one gear type.
drill motor gear noise arshacker Motors 2 04-02-2003 19:52
Please help! Grease in the drill motor gear box? archiver 2000 2 23-06-2002 23:07
Info on gear on drill motor archiver 2000 2 23-06-2002 22:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
