Re: Official Beacon Tracking Code Posted
-Kevin |
also, it's best to have the official code only posted certain places, as updates (if necessary) would be painful with multiple locations.
so we use beacon on EduRobot and Tracker Code on the FRC robot to see if it works???
Kevin,
On your website, you mention that there are two versions of receiver.c. Quote:
I was using a solderless breadboard to build and test the beacon and sensors before committing to a design. Using the EDU, I was going to marry the beacon driver and the receiver code into one program to get a better understanding of how this stuff works. (i.e. one program to both flash the beacons and detect it with a sensor) Unfortunately, my first attempt at that resulted in a flashing red program state LED on the EDU. I will work on it again tonight. Are there any considerations/conflicts when including receiver.c in the beacon code? |
-Kevin |
I have noticed that the diagram that FIRST has posted on the photo sensor is wrong if you go by the picture. If you follow were pin 1 goes it is correct but looking how the sensor ir positioned on diagram pin 1 and 3 are swapped. We caught this by looking at the datasheet from http://www.kevin.org/frc/TSOP34840.pdf
I hope this will help any other teams that might be having some small problems with the IR sensors. Matthew Ubergeeks |
-Kevin Last edited by Kevin Watson : 28-01-2004 at 22:58. Reason: Icky grammer. |
I was wondering, once the Turn_To_Target state switches to the Drive_To_Target state, what is it supposed to do since Drive_To_Target is blank? Does that code have to be implemented by ourselves?
Code:
case DRIVE_TO_TARGET: case PASSED_TARGET: |
| What is your most prefered programming language? | Hailfire | Programming | 156 | 19-01-2005 21:42 |
| InfraRed autonomous code ... | mtrawls | Programming | 1 | 11-01-2004 00:25 |
| Autonomous code | PBoss | Programming | 7 | 14-01-2003 15:29 |
| Does your team use the Default code. | Jeff McCune | General Forum | 2 | 09-01-2003 14:46 |
| Patent source code? | Kyle Fenton | Chit-Chat | 3 | 20-10-2001 17:53 |
