What to do with autonomous
What are your plans for autonomous this year? Will you choose to track the IR beacon? If so, how do you plan on finding your ball without knocking over the opponent's? The beacon is in betwen the two?
Line tracking? Dead reckoning based on timing? Dead reckoning based on encoders? Dead reckoning based on gyros and accelerometers? Something else entirely? Whatever is is you are doing, please explain. Our team is doing an encoder based dead reckoning system somewhat similar to what wildstang did last year, only it is expected to be much more precise. We have a seperate PIC18F252 dedicated to nothing but counting encoder pulses and computing the trig transforms necessary to figure out where we are. We have figured out a rather clever way of doing trig functions extremely fast, but don't expect any leaks on that. The IFI processor will take the position data from the secondary processor, and run a rather complex control algorythm to make the robot follow preprogrammed paths. |
Re: What to do with autonomous
Dont do line following!!!!!!!!!!!!!! I cannot emphasize how slow line following really is. We tweaked our bot enough last year that we got it to do it just about as fast as you could, and it took the entire 15 seconds. Sure, it won us Driving Tommorow's Technology, but it was the stem of many problems.
Cory |
The infrared beacon is in between the two balls, so yours is always inbetween the robot and beacon and opponents is opposite beacon.
That is true, however, the problem we saw wasnt the sensors, it was that if you wanted to run the robot at a speed significant enough to get anywhere quickly, you would overrun the line, and never be able to get back, although now that I think about it, since the line is far straighter, you might be able to get it to work well. I would still lean towards another mode, however. Especially with these IR sensors. It seemed as if Woodie was hinting that we would *need* to be able to use sensors in the coming years (Or was it Dave?).
$0.02 |
I belive it was Dave who hinted at the IR use. I am not sure what our team is planning yet, if anything. We probably wont go for the ten point ball. We may use dead reconing to move under the ball drop, for a possible bot design for catching the balls. Well, if we can figure out dead reckoning, being our main porgrammer left us. If anyone can help me learm more about it, it would be greatly appriecated.
Since the line is much less "Curvy" this year, line following could be optimized to go faster than last year. HOWEVER, I would strongly recommend against that if possible. In many applications, not just FIRST I have tried line following and have not been satisfied with the results. Most of the time it is either too slow or loses the line too easily. Granted, there are applications where line following IS a very viable option, but I'm pretty sure that this is not one of them, especially since FIRST gives you the sensors and code to use the IR beacons, especially since they seem determined to make sure they are fully utilized in the future. So, of course, ultimately it is up to the individual teams, but personally, if you ask me, then it is not your best option.
I made some tests following the line, actualy, many of them. The best results came out using six sensors! Use them in V, and put them as far as you can from the robot's rotation center, keeping a distance of 6'-7' between the center sensors, so the robot can go with two or three corrections only. In 30 times we got there everytime between 7 and 8 seconds, never loosing the line. The limit is your drive system! |
BTW, we were not computing our trig in the conventional way. We employed many optimizations on these calculations that I would consider standard for this situation, and the result was that converting our heading and distance to an (x,y) coordinate took only a few clock cycles. |
#12
If we are duplicating your design, i promise, this is not intentional. I am the one responsible for the design of our system and if it is turning out like yours then thats probably because we followed similar descision paths and came to similar conlusion about how to effectively implement such a system. |
#13
As for the 6 inch accuracy, that comes from somewhere else. While we know our position with much better accuracy than that, we would consider to have hit a waypoint if we were within a 6" square around it. This is necessary to prevent the robot from reaching a waypoint and then overshooting it due to coasting, and then having it try to keep getting closer and closer to it. I imagine you'll find that you need a similar concept as well. |
#14
It's not a big deal, but I hate to not have a reason. :-) Thanks. |
#15
Seriously, we chose 6" because we figured that it got us "close enough" to our point. Last year's game didn't require much precision, just a quick turn and dash up the ramp. If we were a couple of inches off it didn't really matter much. We wanted to run full speed the whole time and not worry about going back to a waypoint if we overshot it. We didn't do much testing, we just picked a box that was big enough to work. We made this number configurable per waypoint so changing it just required updating the range in our waypoint list. |
| A better autonomous method.. | randomperson | Programming | 4 | 24-02-2004 18:02 |
| Electrical componenets for autonomous navigation | maclaren | Electrical | 10 | 18-12-2003 02:28 |
| crazy idea for autonomous | Mike Ciance | Programming | 16 | 24-04-2003 21:50 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
| Autonomous Kill Switch | UCGL_Guy | Programming | 8 | 15-01-2003 17:39 |
